[OH] Cleaning out garage. Slicks fuel injection v6 stuff
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I have 2 sets of fuel injectors. Sets of 6.
First set are oem 4.2l trailblazer ones. Ohmed out at 12.1 for all. Flow rate is 21lbs/hr@43.5psig.
Second set are 3100 3400 ones. Ohmed out at 12.6 for all. Flow rate is 20lbs/hr@43.5psig
Asking 65 dollars for each set shipped to anywhere in lower 48.
I also have a set of slicks mickey tompson. Et drag 28x10.5-150 they are warn a bit and but have some life left I'm asking 75 bucks for the pair of them but is local pick up only northwest ohio area.
I also have a set of front runners. Maroso ds2 28x4.5x15 they are also worn but still in good shape. I'm asking 75 dollars as well for the set. Local pick up only in northwest ohio area.
I have a delta 260 grind cam for a 2.8 3.1 v6. Good cam. Wear is normal. About 5k miles on cam. Can provide cam card. Asking 65 dollars shipped anywhere in lower 48.
7730 ecm. No memcal (eprom). Works great I have no need for 2 spares. 60 dollars shipped anywhere in lower 48.
I have a brand new gm 2 bar map sensor. Never used. 40 dollars shipped anywhere on lower 48.
I recently changed my piping to 3 inch charge piping. I have (5) 90 degree 2-1/2 couplings. I have (6) 2-1/2 inch straight couplings. I have (3) 3x2-1/2 inch reducer couplings. I also have some pieces of 2-1/2 inch alum charge piping. Basically what you see in the pic. I'd like 75 bucks shipped for all of the couplings and piping. Shipped anywhere in the lower 48.
I have a 3.4l fuel rail fuel harness and the fuel injectors which are listed above. I also have 2 throttle body's with the sensors included in them. Make me a offer.
Also I have a set of custom length pushrods for a 2.8 3.1 3.4 hybrid conversion to where you use a fwd top end on the gen1 rwd block. I got these from wot. I have 2 complete sets one being on my current car so I have no need for the 2nd set. Can provide lengths if some one has interest. You will have to have custom length rods if you do a hybrid swap so you can save quite a bit by buying these. 90 dollars shipped anywhere in lower 48. Iirc from wot they cost about 160 before shipping.
Car: 1991 Camaro RS
Re: Cleaning out garage. Slicks fuel injection v6 stuff
Bump
Car: 1991 Camaro RS
Bump open to resonable offers or trades.
Car: 1991 Camaro RS
I also have some big blk chevy stuff nib.
Std. Rod bearing kit. 65 bucks shipped
Timing cover gasket set. Tossed in with rod bearings for free.
Car: 1991 Camaro RS
I also have 80lbs per hr high z injectors for sale. New. Set of 8 for 300 bucks shipped
I have a 1 year old borg warner s366 turbo for sale. Still like new. 550 bucks shipped.
God speed wastegate 75 bucks shipped
3 inch couplings cold side piping.
Big intercooler. 3 inch inlet outlet. 120 shipped.
A walbro 400lph fuel pump brand new in box. 120 shipped.
My headers for my turbo v6. 400 shipped
Still have lots of hybrid stuff. Dis stuff. Intakes heads. 981 behive springs on the heads along with new seals exc. Reluctor wheel on harmonic balancer for dis conversion.... lots and lots of stuff. Pm for more info or pics
Also I have a sniper efi n20 kit. I have alot of jets as well to throw in. Loaded with goodies. Digital window switch, purger, Hobbs switch, heater, ts 2 guages one for a piller incar and one on the bottle. Im asking 550 bucks shipped for all n20 stuff. N20 bottle is full can't ship it full. Easly 900 bucks invested and it's literly one year old or less. This is a good set up and rarly used. Pm for pics and better info.
I also have a gm 3 bar map sensor gm boost solenoid and a few 7730 ecms.
I'll also be selling my aldl cable, moates adapter and 5 chips, as well as a burn2 burner. 140 shipped for those.
I'm sure there is more and will update this later. Thanks for looking.
Car: 1991 Camaro RS
Bump on all parts. OBO and trades as well are welcome
Car: 1991 Camaro RS
Rear slicks are sold!
Bump on other parts.
Car: 1991 Camaro RS
Update slicks are sold charge piping is sold 1 camshaft is sold custom length pushrods are sold
Car: 1991 Camaro RS
Update. All parts sold except a 9 inch tail th350 trans. Reverse full manual valve body(tci) I rebuilt it one year ago. Works fine when pulled. Local pick up only toledo ohio area. $350
Nib never used hughes gm45 tq converter. Th350 dual bolt pattern.
$500 plus shipping or local pick up in northwest ohio. List at $650 new. My loss.
Pics on request.
Pics on request.
C409
06-28-2016 06:24 PM
