[VT] 88 IROC PART OUT
Old 11-19-2016, 08:55 AM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
88 IROC PART OUT
HAVE THE FOLLOWING ENGINE/DRIVETRAIN/MISC PARTS FOR SALE
-MAF SENSOR-sold
-CHARCOAL/EVAP CANISTER-$15
-COOLANT RESEVOIR-$10
-WASHER FLUID RESEVOIR-$10
-TPI AIR BOX-$30
-TPI THROTTLE CABLE-$10
-TPI CRUISE CONTROL CABLE-$10
-TPI CRUISE CONTROL SERVO WITH WIRING-$25
-SPEEDO GEAR HOUSING FOR T5 WITH CABLE DRIVE-$10
-TPI BELLOW INTAKE BOOT-sold
-ALTERNATOR-$20
-A/C COMPRESSOR-$25
-CLUTCH HYDRAULICS(RECENTLY NEW SLAVE CYLINDER WITH MASTER AND RESEVOIR ASSY COMPLETE)-$35
-TPI ENGINE WIRING HARNESS,UNCUT, FROM C100 TO ECM/C207 PASSENGER CONNECTORS( HAS HAD MAF CONNECOR REPLACED)-$70
-COMPLETE INTERIOR VEHICLE WIRING HARNESS-sold
-v6 t5 transmission-$75
-TAILIGHT HARNESS-$25
-HEADLIGHT HARNESS-$35
-TRANSMISSION CROSSMEMBER-$20
-TORQUE ARM MOUNT-$10
-FACTORY T5 SHIFTER-$10
GAS TANK WITH NEW DELPHI PUMP-$125
10 BOLT DRUM 3.23 LSD REAR AXLE-$125
PM ME FOR NEEDS AND ZIPCODE FOR SHIPPING EST.
HAVE OTHER PARTS FOR SALE HERE
INTERIOR: https://www.thirdgen.org/forums/inte...-part-out.html
EXTERIOR: https://www.thirdgen.org/forums/exte...-part-out.html
Old 11-21-2016, 02:33 AM
On Probation
ktthecarguy's Avatar
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Re: 88 IROC PART OUT
PM sent
Old 11-22-2016, 01:03 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Bosch MAF Sensor and TPI bellow/boot - zip code 78213
Do you have pictures and do you have any of the fender to body bolts?
Old 11-22-2016, 07:02 AM
91rs1022's Avatar
Car: 89 Camaro RS
Transmission: 5 Speed
interested in the engine harness and throttle cable shipped to 48723
Old 11-22-2016, 08:19 PM
Harness and cable 80 shipped
Old 11-22-2016, 08:20 PM
65 shipped
Old 11-22-2016, 08:25 PM
Please email me @ 9manastacio@gmail.com about parts if I haven't gotten back to you, I can't pm for some reason from my phone.
Old 11-23-2016, 01:44 PM
Lucid's Avatar
Do you take Paypal?
Old 11-23-2016, 07:45 PM
yes Lucid. pm sent
Old 11-23-2016, 09:17 PM
Lucid's Avatar
I should have asked this before, is the MAF sensor in good working condition?
Also looking for:
-metal ashtray in console
-rear 6x9 speaker brackets
-front fender liners
-fender mounting bolts
Old 11-24-2016, 01:26 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Got a pix of the clutch hydraulics
Old 11-24-2016, 09:43 AM
the maf is in good working shape, tested with snap on vantage meter/dmm. i have the rear speaker brackets, fender liners, and have the metal ashtray for the venter console, but only the rear one, not the front one by shifter(selling with console plate)
Old 11-24-2016, 10:23 AM
Old 11-24-2016, 04:36 PM
Lucid's Avatar
I definitely want the MAF Sensor and MAF boot, payment sent via Paypal.
Could you update me on shipping, same zip code 78213 on the rear speaker brackets and the fender liners? Pictures if you got them.
Old 11-24-2016, 05:31 PM
Here are some pics lucid. as stated the fender liners are intact, but have a tar like substance, kind of like that on asphalt shingles, that comes off. speaker brackets had original speakers installed. I sent you a pm as well
Old 11-24-2016, 07:05 PM
heres a pic of clutch hydros
Old 11-25-2016, 12:19 PM
On Probation
Hi there,
I am interested in the ale. any leaks in the oil seals? can you ship it?
Old 11-25-2016, 02:19 PM
there arent any leaks. i will have to check on shipping, there arent any big shipping companies around me that would be reasonable on shipping
Old 11-26-2016, 03:29 AM
On Probation
Hi 9manastacio,
Have you tried using Greyhound Bus? They offer shipping on their busses. It takes longer to ship, but their rates are usually very cheap, and they can ship bulky items like hoods and axles. Can you check on shipping to zip 48152?
Old 11-27-2016, 10:33 AM
Still lots of parts, complete interior, headlight, and engine wiring harnesses ready to ship!!
Old 11-28-2016, 03:30 AM
Lucid's Avatar
Parts arrived in great shape. Left positive feedback on iTrader.
Old 12-01-2016, 07:35 PM
still lots of parts available. check the links to my interior and exterior parts that are available as well!!
Old 12-18-2016, 07:12 PM
Tis the season to give..me your zipcode and Ill give you a quote on parts
Old 01-07-2017, 02:26 PM
what parts do you need?
Old 01-13-2017, 10:37 PM
Third_Gens_Rule's Avatar
Car: 1990 Camaro Rs
Engine: Stock LO3 305 TBI
Transmission: Stock 700r4
Axle/Gears: 9 Bolt 2.77
Pm sent
Old 02-04-2017, 05:05 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
PM Sent
Old 02-05-2017, 06:16 PM
85@IRocZ's Avatar
Car: Red 91 B4C, Burgundy 91 B4C,89 gta
Transmission: Auto, Manual
Axle/Gears: Posi
Do you still have T5 shifter and how much shipped to 32708? Thank you.
Old 02-11-2017, 09:42 AM
still have lots o parts here
Mya1 (10-23-2019)
Old 05-19-2017, 02:31 AM
marcial88's Avatar
Car: 1986 Camaro Z28
Engine: TPI 305 CI 5.0L V8 LB9
Transmission: AUTO 4 SPD 700 R4
Axle/Gears: 3.23 RATIO
WTB firewall harness rectangular grommet. 90044
Old 05-20-2017, 01:14 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Crossmember still available?
Want to replace the hydraulic transmission mount on my '88 T5, so I need the early style crossmember. ZIP 37918.
Old 05-20-2017, 07:58 PM
mstng5pt0klrz28's Avatar
Car: 1985 Z28
Coolant resevoir still available? How's the inside?
Old 05-25-2017, 03:27 PM
Kblakney's Avatar
Car: 1991 Z 28
Price for the A/C - smog bracket, just the bracket don't need the idler pulley or anything on it. shipped to South Dakota 57108. thanks
Old 05-27-2017, 10:48 PM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
I pm'd you and emailed you!
Old 05-30-2017, 10:27 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i need the cruz vac cut off. it has no electrical connections, just the vac line. it will be at the clutch pedal mounted like the brake light switch and is usually black.
Richard
Old 06-04-2017, 05:34 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Old 07-07-2017, 10:20 AM
Want a title? Post!
dhansen's Avatar
Need the following for an 89 Iroc, 305, manual:
1) Exhaust cat bracket / hanger assembly
2) Gas tank heat shield
3) Leather wrapped steering wheel
Shipped to Minneapolis
Mya1 (10-23-2019)
Old 07-07-2017, 11:04 AM
Code1racing's Avatar
Car: 1989 Rs
Engine: 355
Axle/Gears: 3.42 Gear
Still have engine wiring harness? How much
Old 07-14-2017, 11:46 AM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
do you have a coolant temp gauge or the whole gauge cluster maybe?
Old 07-20-2017, 11:28 PM
85irocZ2819's Avatar
Car: '87 z28
Engine: 383
Transmission: t56
Axle/Gears: 10 bolt 4:10
looking for the headlight harness does it have the foglights in it as well
