Parting out 1991 z28, 5.7tpi
Engine: 4++,350 & 305 CIs
Re: Parting out 1991 z28, 5.7tpi
Edited since I'm old and forgetful PM sent
PS 89irocz355, please check your email, and PMs.
Thanks, I just got a pm about it as well. I knew this but some reason It doesn't stick in my rock. Mental block and getting old sucks
I'm used to the maf cars but for this 92, i'm going 305 tpi to 350 tpi, haven't looked to see if the knock sensor or the esc are setup the same for both motors?
I'm sure someone will correct me if I'm wrong, but the knock sensor and chip are specific 305 vs 350. I'd imagine a person could have limited success running the complete 305 complement of parts on a 350, and leave the computer thinking the car is a 305. But it'd probably work better to use a 350 KS and chip.
I'm in a similar boat. I've got a complete 305TPI 5spd setup, that's going to go on a 350 with a T56. Neither stock setup is going to match up completely, but a 350 setup would probably be closer... IDK neither is ideal, fortunately I've got a long time to think about it before I'm ready to start the engine.
1 Post
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
How much for the 2 wire harness that connects the coil to the ignition control module under the rotor on the distributor? I believe it is the plug on the coil closest to the firewall. Shipped to NJ.
MantyZ28
02-13-2017 04:59 PM
