[FL] Corvette Aluminum 113 Heads
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... SOLD ... SOLD ... Pair of 113 Corvette Aluminum heads with Comp Cams 987 Valve Springs ... good for .560" lift Medium/Hot Hydraulic Roller Cam ... heads have been surfaced and valve guides were machined for PC Valve Seals ... ready to bolt on and go ..... $650.00 Shipped to the lower 48 .....
Car: '87 Vette C4
Re: Corvette Aluminum 113 Heads
..... 58cc combustion chambers ... good for about 1 full point rise in compression .....
Car: 89 Firebird
Engine: 355 TBI
Gen 1. These were the L98 Vette heads used from mid 86-91 on Corvettes. Ive seen em used on 305 builds. Great heads.
Car: '87 Vette C4
..... I have the stock OEM rocker studs , self-aligning rockers , pushrods , and the assembly plates (while they look like guide plates , they are not hardened and were only used as an assembly line aid) ... I would not recommend using any of these with any performance cam .....
