[OK] PARTING OUT 1991 GTA LB9 5.0/AUTO
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
SERIOUS REQUEST ONLY.
Payment: Paypal, Money Gram, Chase bank
I ship WORLDWIDE
I ship within 24-48 Hours of payment received NO BS !!
dmcman108@yahoo.com or SERIOUS READY TO PAY call 3 6 0 515 77 26
Located in Oklahoma City Area
1991 GTA
LB9 5.0 TPI F code
700R4
2.73 Posi Alum Drum Rear GU2/G80
120 MPH IP cluster
130K MILES Hasn't been on road since 2004
I ship WORLDWIDE
1991 GTA
LB9 5.0 TPI F code
700R4
120 MPH IP cluster
On Probation
Re: PARTING OUT 1991 GTA LB9 5.0/AUTO
Bump all still available
Dave
Dave
Car: 1990 White GTA
Engine: 5.0L
I'm looking for seats front and back light gray.
Erenscott@sasktel.net
On Probation
But only GTA seats I have are these in beechwood tan cloth
Dave
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Would you be willing to separate the cylinder heads from the engine and ship them?
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I would be interested in the transmission to rebuild and have as a spare if the price was right and we could get it to Malvern Arkansas through the bus line or some kind of reasonable shipping.
Car: 87 K5 Blazer
Engine: 355 TPI SD
Axle/Gears: Corp 10 Bolt 3.73
How much for the AC/tensioner pulley bracket?
On Probation
LAST CALL !!!!! CAR GETTING CRUSHED SAT 25TH
Transmission: Pro-built 700R4
Was this car crushed or can I still get a couple of parts from it?
Double post
I need one of the small brake lines that goes from the master cylinder to the prop valve for a '92 Trans Am w/rear drums.
The rear most line to be specific.
Thanks for looking.
On Probation
UPPER/LOWER INTAKE
THROTTLE BODY
SOLD
THROTTLE BODY
SOLD
Car: 87 GTA
Transmission: TH350
Axle/Gears: 3:42
What is left engine wise? How much $? I stay in The Dallas area and can drive up there and pick up if price is right. Thanks
On Probation
Throttle Body
ECM AND HARNESS
Lower manifold
Upper manifold
Upper Rear plenum extension
Runners
Injectors
Coil bracket
Map sensor bracket
Throttle cable bracket
Fuel rail
Thermostat housing
All nuts/bolts/plastic and rubber hoses connected to above items
#45
what about the rear axle ??? any chance on parting with the axle shafts ???
#47
1 Post
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
Here is what I'm looking for the black plastic panel that goes under the dash that has the fuse panel door. Wound a auto and a manual be the same?
Steve
Steve
#48
Do you still have the car? I'm looking for the small white plastic rectangular piece that the shifter boot is attached to (commonly stapled). Only the smaller piece the boot is attached to, not the larger part that bolts to the shifter plate. I don't care about the condition of the boot itself. What are you asking for it shipped to 93010?
#50
On Probation
Sorry car crushed
