runner torx bolts, spark plug wire looms and throttle cable loom
Car: 89 Formula 350 Original Owner
Engine: 5.7
I'm just looking for some small things. I figure someone probably has everything I need lying around in a box. If you got everything and don't want much for it let me know. Simply looking to clean things up under the hood a little. (1989 Firebird Formula 350)
1) A original set of torx head bolts for the intake runners.
2) All the original spark plug wire looms.
3) Original heat shield on drivers side exhaust manifold.
4) Original throttle loom located on the drivers side stud on top of the intake runner.
5) Original connector for the coolant fan switch located on bottom of the passenger side head above the starter.
I live in Shenandoah, Virginia 22849 if that helps estimate shipping.
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
Re: runner torx bolts, spark plug wire looms and throttle cable loom
i have the oem bolts ur looking for and the loom on the drivers side stud
Engine: 5.7
How much can you sell them for?
Car: 89 Iroc Convertible
I should also have the bolts and the throttle cable loom for the stud
86IROC112
10-13-2015 03:59 PM
sjorgens
10-01-2015 07:54 PM
