GM Performance 12530282. Anyone bought one?
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
I have a rod knocking in my engine. (Stupid trans servo hanging up caused me to over rev it one to many times I guess.)
It only has 58,000 miles on it but its a 305 so I am going to pull the plug and buy another motor instead of doing a crank kit.
I am wanting to buy this motor: http://www.jegs.com/i/GM%20Performan...0002/-1?CT=999
And either a high-flow base plate or Stealth ram. Before I put this in I would also change the valve springs or cut deeper pockets and change the springs for a better cam. I would also do a little port work to the heads if I thought they needed it.
Seems to me I should be able to go over 400hp for cheap this way..
Sorry for the book.
Anyone used this engine before? Any good.
Sorry for the book.
Engine: 4++,350 & 305 CIs
Re: GM Performance 12530282. Anyone bought one?
I have used one of those shortblocks before. Its still up and going.
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
Hey man, how did this engine turn out for you? I ordered the same exact one and put my TPI set up on it with some hooker comp shorties. Probably will get it fired up in a day or two.
86IROC112
09-07-2015 01:37 PM
