Carbed L31 vortec plug and wire recommendation
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Needing help figuring out which set of plugs to go with for my motor, I'm having issues with my plug wires wanting to get against my manifolds and want a recommendation on the best plugs for my motor. My build is this, stock L31 block,vortec heads, comp cams xr270hr cam, edelbrock performer intake, Carter AFB 600 vac secondary carb, stock tpi manifolds, accel hei distributor
84LsxZ28
02-09-2017 04:21 PM
