Whats the best exhaust? What are the best headers?
Old 11-28-2007, 06:28 AM
  #151
northeaster79's Avatar
Car: 89 WS6 FORMULA
Engine: LB9 305
Axle/Gears: 2:73 posi
Re: Whats the best exhaust? What are the best headers?
excellant thanks,so when buying a high flow converter I'll need one that has the air pipe.
Old 11-28-2007, 01:29 PM
  #152
poodu45's Avatar
I am putting togeather a twin turbo 350 and got tired of looking for decent headers so we welded up our own equal legnth and front turbo flange-I used 2" tubes and a 4" collector-my question is why can't I use a square 4" collector tube out of 1/8 thich stock- this would help disapate heat and be easy to reduce to a t4 flange-our headers will fit any applacation you can use shorties on and will work on a/c cars also
Old 12-06-2007, 01:32 PM
  #153
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
is there any way to get these
everywhere I look they are discontinued/not made anymore...
http://www.hawksthirdgenparts.com/in...OD&ProdID=1168
Old 12-06-2007, 02:35 PM
  #154
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The operative word is "DISCONTINUED".
That means classifieds, eBay, racingjunk, etc.
Old 01-20-2008, 12:49 AM
  #155
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
i would have to say mufflex hands down!!!!
Old 01-24-2008, 05:02 PM
  #156
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I am making them now...and better.
They are available wth or without AIR tubes. PM me for details.
Old 01-24-2008, 05:16 PM
  #157
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have the Hooker 2210 on my Camaro with a little custom modification for that dreadful # 7 plug that usually causes problems or require a shorty plug. I had mine cut and extended to make a little more room. My Y-Pipe was custom made "mandrel bent" in Joilet, Il. for under $300. Here are a few pics. The whole system will be ceramic coated as soon as I get back from Korea in March 08.
Headers Mods.
Old 01-26-2008, 04:09 PM
  #158
skinny z's Avatar
Hey DLT504!
Finally a long tube install that works. I've seen a LOT a 3rd gen install's (Dyno Don's shorties are some of the best but I want LT's). I particullarly like the cut out's. I can see the best of both worlds here. Fully muffled exhaust in the stock location for cruising and tuned length open headers for track days.
Question: Are those pre fab s-extentions or did you have them made to suit the custom y-pipe?
Was there an option for solenoid activated cut-outs?
Kevin
Old 01-26-2008, 06:00 PM
  #159
DTL504's Avatar
Originally Posted by skinny z
Hey DLT504!
Kevin
Kevin,
The cutouts are from Summit Racing, already fab. I have electrical cut outs from McCord. Here is a link to both items.
Summit 3" Cutouts Part# SUM-670137
http://store.summitracing.com/partde...5&autoview=sku
McCord Electrical Dual Power Plates for 3" Cutouts
Code: MPP2-32
http://mccordcg.com/Merchant2/mercha...egory_Code=MEC
Old 01-26-2008, 07:13 PM
  #160
skinny z's Avatar
DTL,
The pipes between the header and the cut out look like aftermarket s-extentions.
Or are they custom like the y-pipe?
Old 01-26-2008, 10:20 PM
  #161
DTL504's Avatar
DTL,
Sorry I did not understand what you meant in the previous post.
I have MagnaFlow's transition Y-Pipe, cost about $27.00. Scroll down to the Magnaflow pipe and select the proper pipe. I have the 124-10798 Magnaflow Transition Y-Pipe, 3" inlets / 3" outlet, 10" length.
http://www.thunderracing.com/catalog...&vid=3&pcid=54
Old 01-27-2008, 11:38 AM
  #162
skinny z's Avatar
Thanks for the info DTL.
My 86 IROC is heading to the fab shop in the next couple of weeks so the pics go a long way.
Now the big question! Do you have any 1/4 mile performance data (I've checked your dyno sheets) with full exhaust as compared to the cut outs open?
I can see a couple of tenths in the 60' times if the exhaust tuning goes like I anticipate.
Old 01-27-2008, 02:48 PM
  #163
DTL504's Avatar
I do not have any 1/4 mile times...
Old 03-24-2008, 12:42 PM
  #164
Camaroman575's Avatar
Car: 1988 Chevy Camaro
Engine: 305 V8
i have an 88 305.
i have new exhaust from the cat back. magnaflow converter, 3in midpipe, flowmaster 80 series single in duel out 2.5in.. and stock manafold.
i want headers. best headers for a gooood price for my 305 annd headers that will work with my single exhaust.???
help please.
baseballa5757@yahoo.com
Old 03-25-2008, 12:49 AM
  #165
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Once again, this thread is NOT for asking what you should put on your car. This thread is for reading about the differences between header and exhaust choices and making your own decision about what you should put on your car. If you still have questions after reading this thread, then you can start a new one.
Old 03-25-2008, 12:11 PM
  #166
Engine: 305 V8
Exhaust Post your questions and suggestions about stock or aftermarket exhaust setups. Third Gen exhaust sound files and videos.
i had a question. and you have to be a **** about it. if anyone knows anything that will help me, it would be much apprecated. thank you.
Old 03-25-2008, 10:32 PM
  #167
Kevin91Z's Avatar
You're absolutely right. This FORUM is the place to ask questions about the exhaust setup on your thirdgen.
But, this particular THREAD is not for asking questions. It is for providing info on the best bang-for-the-buck exhaust systems based on personal experiences with them.
If you have a question, start a new thread. If you have something to add to the discussion about exhaust systems mentioned in this thread, you can post it here.
Old 03-26-2008, 05:23 AM
  #168
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I just got a picture of this so I thought I'd share for those trying to figure out how much work is needed to install the Hedman long tubes.
The driver's side header hits the A-arm perch. Solution - cutting off a piece of useless metal protruding out right there. This bothered me for a while until I saw exactly what needed to be done and I realized it wasn't that big a deal, to me anyway.
And yes, my A-arm bolts are backwards, I know.
Old 06-19-2008, 03:21 PM
  #169
ino
ino's Avatar
Car: 87 firebird
DTL that is a very nice setup you have there. How much did it run you?
Old 07-02-2008, 04:18 PM
  #170
Z THANG's Avatar
I went with 1 3/4" Hooker Super Comps (long tube) with 3" pipes into two-chamber Flowmasters dumping at the rear axle. One of the best sounding setups in my opinion, well next to open headers, hehe.
I put tail pipes on it at one point when I was having to haul the kids around, and it killed the power, not to mention made it more cackly sounding. I would definately go with setups with the mufflers dumping before the rear axle for cars that have healthy motors.
Stock setups, the best I had was a Y pipe running in to 3" pipe back to a Flowmaster original replacement muffler. It gives it a nice sound, actually pretty loud for a "one in two out" setup. I thought about going back to this since my kids now want to ride with me and I'm sick of smelling like exhaust.
Old 07-02-2008, 04:25 PM
  #171
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
DTL I really like your set up. Looks great, I should have done that too mine, oh well, maybe in a few years, lol.
Old 08-11-2008, 07:32 PM
  #172
importkiller198's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 4.10
Hooker headers makes a header that turns in the stock location toward the passengers side of the car, they are ceramic coated, super comp, long tube headers part number 2138-1 you can get them at www.holley.com. Dynomax makes header back dual exhaust kit on www.summitracing.com and has the headers to fit the kit but doesnt come with mufflers. i had to cut a little on the exhaust to fit the long tubes and to fit the flowmaster 40 series but it sounds awesome. I wanted the tali pipes to go out the back so i rerouted some pipes. the part number on the dynomax pipes is WLK-89009. Like i say they are header back without converters but you will be satisfied!
Old 05-09-2009, 06:54 PM
  #173
heartofalion's Avatar
Car: 1991 Camaro RS
Engine: 350LT1
Transmission: Moving on to a T56...for now
Ok, first off it seems this thread hasn't been used in a while so I hope this works. This will be a multi-part two-option question. I have a 91 RS with a 305 only work done to it was a change in the exhaust, now has a magnaflow muffler, straight pipe (sorry emmissions guys). Now I have two choices either keep with the 305 theme, buy another 305 stroke it out to 331 or I have a 350 4 bolt main out of an 86 suburban sitting in my yard i could swap in there. Although this thread is not for motors if anyone can give me their opinions on which I should do I would greatly appreciate it. The other question which does belong in this thread is in either set-up which set of headers and cat should I go with, while keeping the magan flow set-up? Also I have an exhaust shop that does the work for me, can i just go with a custom Y-pipe or should i order one?
Old 05-10-2009, 09:51 AM
  #174
anthony714's Avatar
simple.if you yanking motor no way in hell the 305.stroked or not ,goes back in......period. 350,grab 400 crank any boom.....383...headers,simple,hedman or hooker shortys work fine,edelbrocks are nice units and i think all sell y pipes. buy stuff for what youre driving. long tube headers arent needed for what it sounds like youre doing. plus ground clearence sucks. if youre going to exhaust shop for get y pipe. have em plumb a 2 12" true dual with x pipe. i did, sweet as butterrrrrrrrrrrrrrrrrrrrrr
Old 05-10-2009, 11:31 AM
  #175
bigals87z28's Avatar
Car: Check The Sig
If you are going to do a 383, I would go with a set of large long tube headers.
I would also go with the 350 route. As a 305 fan, if you have access to the 350, do it.
Old 09-06-2009, 12:56 AM
  #176
89iroc-z559's Avatar
Car: 1989 camaro Iroc-z
Engine: 5.7 Tpi
Transmission: 700-R4
Axle/Gears: dont know what this
So if I don't get the 1-3/4 short Headers I can't make any power over 300? And how much hp gains can I expect from the 1-3/4 headers compared to the 1-5/8 ones. I'm curious because this is gonna be my first modification and I don't really know alot about performance engines. So yea any help will b appreaciated.
Old 09-06-2009, 04:20 PM
  #177
Kevin91Z's Avatar
Yes you can certainly make more than 300 horsepower with 1 5/8" headers.
I dont think anyone has done a direct comparison between 1 5/8" headers and 1 3/4" headers. Have they?
I just know the exhaust gasses are hot and want to expand. Larger tube headers help those gasses expand and get out of the engine easier. Up to a certain point of course. You wouldnt put 1 7/8" or bigger headers on a small block unless you're really pushing some air at higher RPMs.
Old 12-02-2009, 02:04 PM
  #178
halotarget's Avatar
Car: 92 RS Heritage
Transmission: stock 5spd
Axle/Gears: looks/ feels stock
ok, i have a bit of a Frankenstein set up, a 350 (.06 over) dual plane manifold holley carb ect. now i'm about to replace the heads (current are from the late 80's L98 and aren't worth their weight) the stock pipe was cut about 8in before the cat and replaced (with a new cat) by a 3" single to a rear muffler than two 2.5" pipes out the back. my aim is for 400bhp as this is impossible with original headers and front y-pipe what is my best plan of action (i am on a budget so nothing to expensive) also no emissions here so i intend to kill my cat.
Old 12-08-2009, 07:59 AM
  #179
hamaf's Avatar
Car: Camaro RS
Engine: GMPP 350 HO 330hp
Transmission: TCI Streetfighter TH-700R
This is really interesting subject. my engine made 331hp(276hp at the wheels) with flowtec 1 1/2 primaries, 2 1/2 y-pipe (looks more like "T") and 3 inch cat-back.
I have a GMPP crate engine (rated 330hp). I think its better to have a little too small(=low RPM torque) than too big IF the car is street driven have automatic gearbox or/and low stall.
Hopefully someone has some dyno results.
Old 12-09-2009, 01:47 AM
  #180
halotarget's Avatar
Car: 92 RS Heritage
i was actually going for a little less street bred, and i have a 5spd so no torque converter to deal with.
anyone know of a good set of long tube headers that will fit a 3rd gen manual decently and let me go over speed bumps?
Old 02-18-2010, 03:14 AM
  #181
bigniq05's Avatar
Originally Posted by 25THRSS
The headers will make a far greater difference than any catback will. I would expect a 25-40 hp gain with full exhaust depending on your setup.
my car is in the exhaust shop now 86z28 305 4bl flowtech shorties non-smog legal into dual magnaflow cats/pipes full exhaust? how much hp would you say im looking at?
Old 02-28-2010, 02:11 AM
  #182
Damoncaravanman's Avatar
Car: 1984 Trans Am aero
Engine: 5.0 H.O. 305
Transmission: 5 speed manual
What is the best route on a performance muffler? I don't want the echo sound, just a deep throaty sound. I have a '84 Trans Am with the 305. I think it is a single muffler dual out. Someone said to go with a magnaflow 40 series??? Any ideas????
Old 02-28-2010, 03:28 AM
  #183
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
my flowmaster 40series was great! Loved the sound it made
Old 06-02-2010, 10:13 PM
  #184
camarochrisz28's Avatar
Car: 91Z28
Hey guys does anyone have a opinion on hooker max flow mufflers ? i read that they are the most free flowing mufflers out there for our cars.....how do they sound is my question ....let me know what you guys think thanx.
Old 06-03-2010, 03:03 PM
  #185
Car: 91Z28
Has anyone used hooker max flow or aerochamber mufflers?.....if so what do you guys think about them?....how do they perform???....i am doing my exhaust and im trying to figure out what muffler i want to go with
Old 06-04-2010, 11:39 PM
  #186
83 Crossfire TA's Avatar
Hooker max flow, magnaflow and the dynomax ultraflow/race magnum are all pretty much the same straight through design, make about the same power for comprable sized mufflers, with slight differences in sound based on the shape of the case, wall thickness, material...
Hooker aerochambers might be slightly more restrictive but are incredible sounding.
Old 06-07-2010, 10:05 PM
  #187
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I have the Hooker Maxi Flow 3in in & out. It is quiet at idle with 10.7 compression and XFI280 Comp cam, smooth cruise sound 1800-2500rpms but very loud at wide open throttle.
Old 06-08-2010, 10:20 AM
  #188
Car: 91Z28
Ok ok well i have heard good and bad for just about every muffler out there so it sounds like just a preference type deal....what do you guys think about flow masters?....i have heard 40 series and they sound good to me.....how restrictive are theses mufflers and does that even really matter for a street car?
Old 06-08-2010, 12:24 PM
  #189
VincentZ28's Avatar
Flowmasters sounds good but you will loose performance like about 20hp. Straight through mufflers has the best performance.
Old 06-08-2010, 06:46 PM
  #190
Car: 91Z28
I think that 20 horse is a little overkill with the loss......the aerochamber have a nice rumble at idle?....do you have a video by a chance?.....i would like to go with the aerochamber however i want a muffler that has a good sound at idle as well.
Old 06-08-2010, 09:04 PM
  #191
VincentZ28's Avatar
You want the sound of a Hooker Maxi Flow, You got it.
Check it out.........http://www.youtube.com/watch?v=DQm-Hmqm1v8
Here's the sound of a Magnaflow Muffler http://www.youtube.com/watch?v=i5LvN...eature=channel
Old 06-08-2010, 09:23 PM
  #192
Car: 91Z28
wow the hooker max flow sounds good how have you tuned your cpu?....where did you buy the Tune chip?
Nice car.
Old 06-08-2010, 09:30 PM
  #193
VincentZ28's Avatar
Nice car.
It was tuned and burned right there on the dyno by Kevin91z in Socal.
Old 07-02-2010, 04:33 PM
  #194
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
I recently bought a dual cat set-up, 1 5/8 air tube headers, 2.5 mandrel y, converters and some pipe after. Will a dual cat fit a single cat car? Is there any modification that will be needed?
Old 07-02-2010, 04:53 PM
  #195
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
dyno don shorties, and gmmg
Old 07-22-2010, 10:20 PM
  #196
malibu2envy's Avatar
Looks pretty good. I see alot of talk about exhaust and I have seen not one mention of TRUE merge collectors??? Why is this, something to due with 3rd gens having a y pipe? The collector is where nearly all power is made in any header other than the pipe diameter and degree of bends. Burns Stainless makes the best merge collectors in the biz(for race applications), you pay for them but you see results good ones! Just curious on this.
Old 09-09-2010, 08:06 AM
  #197
dgedr4016's Avatar
Car: 1992
Transmission: 5 spd
I put Jet-Hot coated Edelbrock headers on my 305 RS and noticed about a 5 mpg increase in addition to the nice boost in power and reduced underhood temps.
Old 09-23-2010, 09:18 AM
  #198
Zyuh's Avatar
Car: 85 Z28
Engine: For now 305
Transmission: For now 700R4
Axle/Gears: Stock 3.23 for now
Hi folks, I have an 85 Z28 305 4 brl., this is my first 3rd. Gen. Camaro, I've owned 5 2nd Gen Camaro. But anyway, my question is this. Can I run true dual exhaust on my Z? My plans r Hedman 1n5/8, 3" headers for now, with a Dynamax 2n1/4" dual exhaust kit. I don't have my license at the moment and the car is in a garage across town so I don' get tempted to drive, so I really havent' checked it out.
Old 09-30-2010, 12:37 AM
  #199
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
This thread has confused me.
Does the hooker # 2055 fit a lg4
Old 09-30-2010, 09:54 PM
  #200
Tafsky86's Avatar
I would agree with you! Although I have Hooker headers... One thing I woiuld like to recommend is getting them JetHOt Coated... do the research... you will find it is the way to go! Not only in finish durability, but, it cuts your engine bay temp in almost half!
Quick Reply: Whats the best exhaust? What are the best headers?
