LT1 swap, lowered and long tubes...am I dreaming?
Old 08-24-2015, 12:55 AM
87iroctheo's Avatar
Car: 87 IROC
Engine: 5.7L LT1
So I spent the day fabing up a custom y pipe to go with my hedmen 68460 long tubes on my 87 IROC with an LT1 with 6speed and a 1.5" drop. Everything looked great up in the air, I had nice flow and tucked everything up tight as possible, then lowered the car back down and man was I wrong. I used the low point on my spohn crossmember to gauge how to hang all the other pipe (and try not to have anything lower than it), and it did not pan out. It just weird angles under there, definitely was not straight forward. I can post some pics later for now I am quitting and don't even want to look at it. My question is what do some of the custom y pipes for LT guys run look like? Also am I dreaming that I can make this work? It looks pretty hopeless at this point, but dam did it sound awesome!
Old 11-27-2016, 11:43 AM
hotrodf1's Avatar
Car: 91 Z28
Engine: 350ci "fastburn 385"
Transmission: T56 / Quartermaster clutch
Axle/Gears: 9", 4.11, Auburn Posi
Re: LT1 swap, lowered and long tubes...am I dreaming?
Bringing the old to the new . . .
Did you ever get this figured out? I'm going to be headed down this path soon too.
On my road racer 91, it has true duals, but the crossmember is custome fabbed so it goes up over the pipes. I also cut the headers in the vertical sections and removed about 2" to gain ground clearance. So it's tucked pretty well. Also, the floor was modifed some and the pipes exit to the right, what would be just behind the passenger seat. Modded the rocker panel as needed, but then braced back to the cage for stiffness. Also frame connectors are welded to the pinch weld. Lots of work to be sure, and not all of it is friendly for a street car.
So not sure if I'll try that route, but then keep going toward the back and over (or under) the rear axle or what.
My '68 Camaro had dual 3" and I went under the axle there, it was way easier (coilovers / narrowed rear / minitubbed, etc, etc). Nice and easy to remove exhaust that way too. Looked wild from the back too Had Magnaflow mufflers that sounded oh so sexy. Might consider that combo, we'll see if there is room.
Old 11-27-2016, 12:05 PM
hotrodf1's Avatar
Car: 91 Z28
Old 11-27-2016, 12:08 PM
hotrodf1's Avatar
Car: 91 Z28
Here's the '68 reference previously, with the under the axle exhaust. Yeah, I should have painted it, never got around to it. LOL
Old 11-27-2016, 12:14 PM
hotrodf1's Avatar
Car: 91 Z28
I'll throw one out there too with side pipes on the racecar.
Old 12-03-2016, 10:32 AM
87iroctheo's Avatar
Car: 87 IROC
Engine: 5.7L LT1
Yea I ended up having an "incident" where insurance replaced my headers for me, so while I was at it I upgraded to the hooker 2210's. I surance paid for a shop to do the y pipe but they did a crappy job. It all hangs so low I hate it! Frirst off for rubbing on any dip in the road and secondly that it looks stupid and cheap hanging below the car for the side you see everything. I wish I didn't have so much money tied into these headers cause I would just go with shorty's, but I kind of like the idea of cutting them up and making my own from them like you did. I still have my damaged hedman, maybe I will try with those first. But right now car stuff is on hold. That USD is killer up here in Canada if you want work done down there, so much for Loydd Elliott cam and heads.
Old 12-03-2016, 12:04 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you're using the Spohn crossmember, ditch it and buy another vendors. Any other vendor's will give you better ground clearance. There is also the possibility of easily making your own crossmember that has humps in it for the exhaust to pass under. The long tube headers aren't the problem, it's your crossmember.
Old 12-03-2016, 02:25 PM
hotrodf1's Avatar
Car: 91 Z28
I will be fabbing my crossmember. Don't have a plan just yet. But I'll take some pics along the way, and maybe I can post it if it turns out half decent.
Old 12-03-2016, 03:29 PM
87iroctheo's Avatar
Car: 87 IROC
Engine: 5.7L LT1
That had crossed my mind a few times, rather than cut up the spohn I would just start from scratch and use the adjustable Torque arm off the spohn.
Old 12-03-2016, 04:39 PM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
I just joined today but it's funny I made my own crossmember. I think you said you have a 6 speed I do to.
You can see the white mounts welded to the tunnel
Old 12-03-2016, 04:42 PM
Biledriver's Avatar
Engine: 383 sbc
Here's the exhaust. Raised the floor for the mufflers I don't have rear seats.
Old 12-03-2016, 07:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
The design looks great and affords the most exhaust pipe room that I have ever seen. My only critique is that the area that you welded to isn't very strong, did you happen to weld a larger and (relatively) thicker plate to the tunnel first? I'd be watchfull about deforming the tunnel if you didn't. I also saw that you no longer have a cross member but rather a transmission hanger or mount. There is the question of is the transmission crossmember's sole responsibility to hold up the tranny or is it also to serve as a brace across the transmission tunnel? I've only heard speculation to that point.
Old 12-03-2016, 10:28 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I have the hawks double hump T56 crossmember and a custom Y-pipe for my Hooker 2210's.
I hate posting those pictures though, all of that surface rust makes me cry. I really need to strip that floor and redo it before the surface rust turns into Rot.
Old 12-04-2016, 12:25 AM
87iroctheo's Avatar
Car: 87 IROC
Engine: 5.7L LT1
i agree, I love th space created, ur my sub frame connectors are welded right across from the trans support for the purpose of solidifying the car from one side to other and what an unbelievable difference it made. Mind you my car is t tops but when used to jack up half the car the opposite side wouldn't even think about lifting up unless you went way up there, after the sub frame connectors you can jack a few inches and the other side will start to lift. Also I cannot live without the torque arm on the mount which has always been my hold up on cutting the spohn cross member. But I still think I will crawl under there this winter and see if I can't come up with a compromise.
Old 12-04-2016, 12:27 AM
87iroctheo's Avatar
Car: 87 IROC
Engine: 5.7L LT1
welcome to thirdgen.org!
Old 12-04-2016, 07:16 AM
Biledriver's Avatar
Engine: 383 sbc
The trans tunnel was actually pretty thick metal and welded in nicely. Been there for 3 years now never cracked or had any shifter movement and me and the wife run it pretty hard with drag radials. Not concerned with it flexing I have welded in subframes and a welded in 8 point cage.
Old 12-04-2016, 09:29 AM
Tibo's Avatar
Car: 1991 Z28 Vert
We may have different definitions on what we each think of as thick enough metal but if the metal hasn't deformed/dented in that area, it's harder to make an argument.
OK, gotcha. 8 point cage would probably help enough with added chassis stiffness to have less need for a transmission crossmember.
Old 12-04-2016, 11:38 AM
Biledriver's Avatar
Engine: 383 sbc
I hated how low my last exhaust was and built it on a whim. I never knew I could buy a crossmember with double humps but making my exhaust higher than my subframes was more than I ever expected.
Old 12-04-2016, 11:47 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Nicely done
customblackbird
08-15-2021 10:16 PM
midge54
09-02-2020 07:13 PM
midge54
12-27-2019 04:14 PM
midge54
01-29-2017 07:00 PM
sreZ28
08-14-2015 07:48 PM
Quick Reply: LT1 swap, lowered and long tubes...am I dreaming?
