Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cam Light SW
Old 06-07-2010, 09:50 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Cam Light SW
Curious if anyone did their own custom or swap out for the light s/w that turns on an off the interior cluster lights, plus the dom light and the headlights. If you don't mind telling me what you used and maybe some pictures? Looking for something that looks good and some-what stock. Its a 89 camaro black bezel.
Old 06-09-2010, 11:22 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Cam Light SW
bump
Old 06-09-2010, 02:56 PM
UDAMON's Avatar
Car: Mazda Protege5
Re: Cam Light SW
i left the headlight switch alone but made the dome independent. but no light turns on when you open the doors.
Old 06-09-2010, 03:04 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Cam Light SW
If this helps, I installed relays to operate the low and high beam headlights. The relays take power directly from the battery. The switch now just activates the relays, dramatically reducing current load on the switch and the old wiring, which will extend its life greatly. Also lights much brighter this way. All newer vehicles use headlamp relays. OEMs finally got smart.
Old 06-09-2010, 04:00 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Cam Light SW
whats the part and any diagram of how to hook it up? pictures?
Old 07-30-2010, 11:45 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Cam Light SW
bump
Frozer!!!
01-19-2024 04:55 PM
camaro71633
09-01-2015 10:24 AM
Jae992
08-27-2015 09:07 AM
Omega
08-10-2015 12:46 PM
Quick Reply: Cam Light SW
