Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
looking for a odd rod end
Old Jul 18, 2010 | 06:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
probably doesn't exist, but anybody ever see/find a good quality rod end, 5/8-18 threads with a 3/4" bore?
I can find them the other way, 3/4 threads 5/8 bore.
Old Jul 19, 2010 | 01:52 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: looking for a odd rod end
I've never seen a rod end like that.
What do you need it for?
Old Jul 19, 2010 | 05:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
secret work
i think i found something that will work though.
Old Jul 30, 2010 | 08:59 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
If you are still looking for something rod end wise, give these guys a try....www.midwestcontrol.com
Old Jul 30, 2010 | 09:03 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I checked out their site before I replied, doesn't appear that they have anything available.
Old Jul 30, 2010 | 09:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i've done a lot of buisness with midwest control, they are a great company. they have the part im looking for, called a "trunion ball" rod end. basicly a rod end with the high misalignment spacers built in, with the same thread size as the bore.
Some of their prices are high if you only need 1 or 2 of the part, but they have quantity breaks that get pretty good with larger orders. they have quite good quality ends too.
Old Jul 30, 2010 | 11:56 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Link to these, please?
Do they have what you are (or were) looking for, with 5/8-18 threads and a 3/4" bore?
Old Jul 31, 2010 | 06:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i was looking for a rod end with 5/8 threads and a 3/4" bore so i could use the misalignment spacers, which would reduce the bore back to 5/8. But since i found the trunion ball ends http://www.midwestcontrol.com/catdis...ort.php?pg=560, i dont need the other rod end since this one already has the misalignment "spacers" built it. It will work to 42 degrees.
Old Jul 31, 2010 | 10:09 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
No details about the secret work yet?
Old Aug 1, 2010 | 03:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
an update/revision on my mumford link setup.
Warlocksirix
Sep 3, 2015 12:26 PM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
