Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
ls1 roadracer project
Old 06-05-2012, 11:48 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
I have been lurking around on this sight for several months now, using the search function. And wow what a huge amount of info, thanks to everyone. Anyway my project is a 86 RS that I am doing a LS swap on. I want to make a street legal road racer. And after seeing the pitfalls of the LS swap ie notching the k member I thought it would be neet to move the motor back a couple inchs and eliminate the pan clearance problem and get better weight transfer also. I knew it wouldn't be easy and I was right, but I cut the firewall out and did it anyway. This mod was very involved and required me remaking one subframe and fabing my own headers, crossmember etc. I have made some subframe connectors and will be building a simple cage to stiffen the chassis. Anyway I have some pics.
Attached Thumbnails ls1 roadracer project-shed-camaro-016.jpg   ls1 roadracer project-camaro-part-2-132.jpg
Old 06-06-2012, 08:54 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: ls1 roadracer project
i want to follow your progress.
Old 06-06-2012, 10:02 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
As you are moving the engine back, you can also reposition the radiator for both airflow and also venting the hot radiator exhaust out of the hood (a very good thing).
Keep us updated!
Old 06-06-2012, 10:24 AM
COTM Editor
BADNBLK's Avatar
Cool! More pics!
Old 06-06-2012, 04:06 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
great to see new (or very rare) mods being done with these cars, good luck!
Old 06-06-2012, 07:07 PM
Z28FAST1's Avatar
Good fab skills ....
Old 06-06-2012, 08:12 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Here's a look at the motor setback and a pic of the trans crossmember. I am trying to gain more ground clearance for headers and exhaust.
Attached Thumbnails ls1 roadracer project-camaro-3-004.jpg   ls1 roadracer project-camaro-3-015.jpg   ls1 roadracer project-camaro-3-011.jpg
Old 06-06-2012, 09:43 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Looks awesome so far, would love some pics from other angles, are you planning to go with a true dual setup? What else is in the works as far as the suspension and rear diff setup? Will you be going with a factoryish torque arm setup and using a stockish panhard bar setup or fabbing up something? Ground clearance at the collectors looks great and looks like you will have an easy time tucking the pipes back and up under the xmember, cant wait to see what you end up doing..
Old 06-06-2012, 11:10 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
89RsPower. Boy you ask a lot of questions. Just kidding. I plan on a single 3.5" stainless exhaust. I am using stockcar weight jacks and springs for the front and back. I did pony up and buy founders lca and panhard bar, they are too reasonable to try and build. I am trying to use the stock torgue arm I don't have it done yet. And the big expense will be a Moser 12 bolt with 4:11s. Don't have that yet, I'm short something called money.
Attached Thumbnails ls1 roadracer project-camaro-3-006.jpg   ls1 roadracer project-camaro-3-023.jpg   ls1 roadracer project-camaro-3-009.jpg
Old 06-07-2012, 12:51 AM
Z28FAST1's Avatar
I take it back, clearance looks a lot better than mine!!!
vs
Old 06-07-2012, 09:14 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
some very cool mods going here, looking forward to see how things turn out!
Old 06-08-2012, 08:44 AM
flash2042's Avatar
Car: 83 Z28
Engine: LG4
LOVING the weight jackers! I was thinking about doing this to mine as well. Mostly for being able to drive to shows with a normal ride height, then dropping it to make it look nice. Subscribing to this thread to see how it turns out in the end!
Old 06-08-2012, 08:11 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Keep us updated!
there is a handfull of us on this forum that are doing this. great idea
Old 06-08-2012, 09:03 PM
83RDRACR's Avatar
Looks very nice, great craftsmanship. I am also building a track day car on this forum under "home brew road racer". I started at the rear and am working forward. I will be following your build. Good luck.
Old 06-08-2012, 09:11 PM
89RsPower!'s Avatar
cant wait to see it when you're done, looks like its coming along really well, that has gotta be the best ground clearance Ive ever seen with long tubes on a 3rd gen
Old 06-10-2012, 11:05 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
After I built my headers I wanted to build some kind of a skid plate to protect them and the oil pan. So I used some 1 inch 3/16 wall tubing to go from the K member to the subframes. But what amazed me was how stiff it made the chassis. You can really tell a differance when the car is on the jack stands. I also got some pics of the multi piece firewall. Good thing no one will see it when the motor is in.
Attached Thumbnails ls1 roadracer project-camaro-part-2-151.jpg   ls1 roadracer project-camaro-3-017.jpg   ls1 roadracer project-camaro-3-018.jpg
Old 06-11-2012, 08:59 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
awesome work, lookin forward to seeing how this turns out
Old 06-11-2012, 10:12 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
I guess I didn't post any pics of the headers. I didn't want to make my own headers but after trying a set of Hawks I realized there was no way I could make them fit. This was my first set of car headers so it was kind of a learning curve.
Attached Thumbnails ls1 roadracer project-camaro-3-024.jpg   ls1 roadracer project-camaro-part-2-141.jpg
Old 06-12-2012, 05:48 AM
flash2042's Avatar
Car: 83 Z28
Engine: LG4
This is turning out to be a very nice piece! I may end up borrowing some of your ideas when I put mine together.
Old 06-12-2012, 04:30 PM
89RsPower!'s Avatar
They look really good, would never guess they're the first set you've ever made. They look like something people would spend a bunch of cash on...
Old 06-12-2012, 04:35 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
This should be good.
Old 06-12-2012, 08:11 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
yeah, those look horrible, but don't worry, I'll take them off your hands 'cause I'm a good guy.
Seriously great work, they look better than some commercially available ones. Keep the great stuff coming!
Old 06-13-2012, 12:06 AM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Thanks for all the interest and positive comments on my project. I will do my best to keep you updated. While my fab skills may be good I'm a electrical idiot so I was hoping to lean on some of you guys when needed. And I'm sure there will be plenty other stumbling blocks.
Old 06-14-2012, 09:53 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Here's some early pics of the Y pipe, shows how they will look. I'm useing V band clamps for the collectors. But because I forgot to measure twice cut once I will be remaking part of it.
Attached Thumbnails ls1 roadracer project-006.jpg   ls1 roadracer project-007.jpg
Old 06-14-2012, 10:04 PM
gp90gta's Avatar
Car: 1990 GTA
This is absolutely an awesome build, cant wait to see the end result, four thumbs up!
Old 06-15-2012, 03:26 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Subbed!
Old 06-15-2012, 03:35 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Very nice work so far. I love good fab work.
Old 06-17-2012, 10:42 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Well here's a mod that has no performance gain what so ever. But for anyone thats has changed a fuel tank will appreciate how it lets the straps hang out of the way. Good or bad I have no trunk now.
Attached Thumbnails ls1 roadracer project-002.jpg   ls1 roadracer project-003.jpg   ls1 roadracer project-004.jpg
Old 06-17-2012, 10:47 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
I also got started on the mounting bracket for the phb. But I won't finalize it until I get the rearend.
Attached Thumbnails ls1 roadracer project-005.jpg   ls1 roadracer project-006.jpg
Old 06-24-2012, 04:55 PM
88camaroluvr's Avatar
What did you do to clean up the metal on your body? It looks sand/media blasted.
Old 06-24-2012, 05:19 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Nice project. The fab work looks great. Looking foreward to updates.
Kory
Old 06-24-2012, 10:38 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
I got the Y pipe done and it was a pain. First I got the angle off, then I warped one of the header flanges when welding it. But its done now.
I also got my cheep ebay seats mounted. Time will tell if they're any good. And Yes 88camaroluvr I had the car sandblasted.
Attached Thumbnails ls1 roadracer project-002.jpg   ls1 roadracer project-003.jpg   ls1 roadracer project-001.jpg
Old 06-24-2012, 11:50 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
You might want to consider a Strange 12 bolt which has factory style torque arm mounting. The moser uses smaller bolts that thread into blind holes to mount the torque arm which sometimes back out.
Neat project, btw.
Old 06-26-2012, 09:02 PM
83RDRACR's Avatar
I too am building a road racer on this forum. Your rotisserie sure makes the under car fab much easier than the overhead welding I have done. I am taking a few ideas of yours on the front subframe and tweaking them to my particular situation. Since you started at the front and I started at the rear maybe we can get some ideas from each other. Here is a pic of my phb mount and the RCI fuel cell I mounted in the stock location.
Attached Thumbnails ls1 roadracer project-gedc0201.jpg   ls1 roadracer project-gedc0362.jpg   ls1 roadracer project-gedc0366.jpg
Old 06-29-2012, 12:54 AM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
After seeing some other members altering their spindles to remove the anti-ackerman I knew I would like to alter mine also. I didn't want to make them pro-ackerman, but just zero the outer tierod with the lower balljoint. In the process this shortend the steering arm by 7/8 of a inch. Which will quicken the steering.
Old 06-29-2012, 03:20 PM
Car: 88 Iroc
Transmission: t 56
Thats pretty cool. did you preheat the spindles before welding? also what type of rod did you use?(assuming you tigged them).
Nice work,
Kory
Old 06-30-2012, 10:25 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
I didn't weld to the spindle I boxed the steering arm with 3/16 cold roll steel. I used the dust sheild bolt hole for one mount and I drilled another by the lower ball joint. Then I put a strap around the arm, then just before welding the strap I heated it to expand it. It took alot of fitting to get it just right. I checked it by removing the bolts and I still can't move the bracket on the arm. I have both spindles done now they seem very solid.
Old 07-01-2012, 08:08 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Good job with the steering arm, I like what you did there
Old 07-01-2012, 01:52 PM
evo-offer's Avatar
really nice job. keep up the good work. are you going to use the original fuel tank?
Old 07-01-2012, 11:00 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
86TA It was your thread that made me realize that these cars have anti ackerman so thank you. Here's a couple more pics. And evo-offer I plan on useing a ls1 tank.
Attached Thumbnails ls1 roadracer project-004.jpg   ls1 roadracer project-003.jpg   ls1 roadracer project-005.jpg
Old 07-02-2012, 03:27 AM
evo-offer's Avatar
OKay. how does it work with the fuel gauge or are you going to use some other gauge?
Old 07-02-2012, 10:19 AM
  #42
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Autometer is what I had in mind.
Old 08-03-2012, 12:19 AM
  #43
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Well I got the 12 bolt and I have mocked it up. And with the ride height I want I think it will hit the forth gen tank. Ideas? I have this posted in drivetrain also.
Attached Thumbnails ls1 roadracer project-v-10-heads-006.jpg   ls1 roadracer project-v-10-heads-007.jpg   ls1 roadracer project-v-10-heads-008.jpg
Old 08-03-2012, 04:18 AM
  #44
dannyboyemt's Avatar
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
subscribed
Old 08-03-2012, 06:19 AM
  #45
flash2042's Avatar
Car: 83 Z28
Engine: LG4
if this is going to be a race car, you'll need a fuel cell instead of a stock tank. look at the rulebook for your series and base off that. chances are you're going to have to do some fab work on mounting it.
Old 08-03-2012, 01:29 PM
  #46
prossi's Avatar
nice solution...how much you want to do my spindles
Old 08-03-2012, 07:56 PM
  #47
83RDRACR's Avatar
I swapped in a ZR2 8.6 axle and replaced the stock tank with an RCI 15 gal fuel cell. I have lowered the car so the top of rear wheel opening is 26 1/2" high and everything clears. More pics on homebrew road racer in this forum.
Great work and craftsmanship on your build. Wish I could weld and fab like that.
Attached Thumbnails ls1 roadracer project-gedc0359.jpg   ls1 roadracer project-gedc0366.jpg   ls1 roadracer project-gedc0245.jpg
Old 08-03-2012, 08:58 PM
  #48
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
The car will be used for track days and street driven so I wouldn't have to run a fuel cell. And I was hopeing to keep it simple and use the 4th gen tank for the LS conversion. I might try a stock 12 bolt cover and see if that helps.
Old 08-15-2012, 11:43 AM
  #49
ThirdGenDemon's Avatar
Car: 1986 Camaro
Engine: LS6
Transmission: Tick Stage 2 T56
Axle/Gears: Moser 12 Bolt
Subscribing to this awesome build!
Old 08-15-2012, 11:59 AM
  #50
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Very nice build! I think you might have to cut and box in the diff cover to give you some more room.... but it will take a real welder or a LOT of preheat to be able to weld it back up!
Quick Reply: ls1 roadracer project
