FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Tire Size
Old 10-17-2006, 08:12 PM
1987Rock's Avatar
Car: 1987 IROC Camaro
Engine: 305 carb
Transmission: 700-R4
Axle/Gears: open diff ?ratio
Tire Size
How big of a tire can you fit into the stock wheel well with the 1987 Iroc 16" wheels? I know the wheels are 16x8 and should be able to fit about a 265 in there, but I'm not sure if the backspace would effect that.
Old 10-18-2006, 02:53 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Tire Size
Hi,
255 on the rear, 255 on the front are probably going
to rub a little
Later
Irocing
Old 10-21-2006, 12:42 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Originally Posted by jaykar
Hi,
to rub a little
Later
Irocing
I had 255's on my '92 fine on the rear slight rubbing on the front. I went back to 245's til I can afford 17" wheels
Old 01-18-2007, 08:48 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Good to know. I was going to put 255 on a set of 16" IROC rims I picked up for $ 100.00. But I'll stick with the 245.
Old 01-28-2007, 01:26 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I had 255/50/16 on, but what if you go with a 60 series? Can I get a bigger footprint? Just curious. I have home made slicks on the rear and I'm shopping for tires tommoro. Thanks, Daniel U
Old 01-28-2007, 03:01 PM
Red92RS's Avatar
Car: 1992 Camaro RS
60 just means the sidewall will be bigger and the tire will be taller, 255 is the width of the tire so that is what gives the "footprint".
Old 01-28-2007, 05:49 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Very true, I suppose I should have been more specific with my ? I am only shopping for BFG's and I realize they only make certain size tires for 16's. I wonder if they make 16/285/60's if that would make a larger foot print(and if it would fit) than the 255/50's that I had. They only offer a drag radial 255 now, and this is my daily driver, so as much as I would love the traction, they aren't practical right now. I suppose I might try thier site 1st. duh
Old 01-28-2007, 09:38 PM
Red92RS's Avatar
Car: 1992 Camaro RS
Are you looking at the BFGs for the best tire or best price? Best price for their base performance tire would be the GForce Sport, Best wearing tire would be the GForce KDWS, better gripping would be KDW, and the best gripping tire and the most expensive would be the KD. If you have a 16x8 wheel i wouldn't go wider than a 255. If you want something like a drag radial the best one I know of right now is Mickey Thompson ET Street and everybody I have talked to loves them much better than BFGs drag radials. Let me know what you want in your tire and I will try to point you in the right direction, as I sell them for a living.
Old 01-29-2007, 12:50 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Originally Posted by Red92RS
Are you looking at the BFGs for the best tire or best price? Not necessarily either. I just feel comfortable with my BFG's.Best price for their base performance tire would be the GForce Sport, Best wearing tire would be the GForce KDWS, better gripping would be KDW, and the best gripping tire and the most expensive would be the KD. If you have a 16x8 wheel i wouldn't go wider than a 255. If you want something like a drag radial the best one I know of right now is Mickey Thompson ET Street and everybody I have talked to loves them much better than BFGs drag radials. Let me know what you want in your tire and I will try to point you in the right direction, as I sell them for a living.
I guess I've always wondered what the IROC would look like with a taller/wider tire. Oddly as it may sound, performance wasn't 1st on my mind. I have ran both the top of the line BFG with both 245 and 255 and noticed little difference. I know the 255 drag radial will out perform the previous tires I've owned. I also know they wont last as long. I woud have just continued with the GForce 255, however, they only offer the 255 in the drag radial. My car gets way to much wheel spin for a tired(160k and burns 1.5 qts. of oil) stock 350(5.7) motor. I go through 1st and scratch 2nd. i know that there are obviously other issues I need to address. I have LCARBS and went through most every suspension part, minus the SFC's. I have 2 wheel peel with the 9 bolt BW rear as in my info@ left states. I plan on relocating my battery over the rear where the spare used to reside. I have removed the A/C and plan on lightning the front end as much as possible as $ provides(aluminum parts to replace iron, tubular front end, etc.). I just thought the 285/60/16 might be a nice change visually and wondered if anyone had tried it. Not sure if it would hit my inner fender. I love the look of my stock 16's. I even contimplated mini tubbing and going with 2 of the aftermarket IROC wheels, having them professionally widened by an inch or 2, and run a wider tire that way. Am I rambling?????? Sorry, Daniel U
Old 01-30-2007, 03:16 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
So I went the cheaper route and had 2 new KDWS mounted in front and had the old front tires (KDWS) mounted on the rear($310 out the door). Whe my '54 truck is finished, I'll have the 255/50/16 BFG Drag radials put in the back. With these wheels I can't easily rotate my tires, so putting drags on it isn't so bad.
Old 01-30-2007, 09:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'll hijack the thread.
Red92RS what is a very good performance tire for the street with the 16x8" rims on my GTA? I have upped the horsepower so much now that traction is a big concern on the street. I use the MT ET Street Radials when I go to the track and hope they still hold.
Looking for rear tires only and the 255/50/16 appear to be the best size. I currently have Dunlop 245/50/ZR16's on the car now and they are not holding in the least. Thanks.
Old 01-30-2007, 09:55 PM
Justin86camaro's Avatar
Car: 86 Camaro
Engine: 350, aluminum heads, carb
Transmission: TH-700R4
Axle/Gears: 7.5 10 bolt, 3.42:1
currently i have 86 sport coupe wheels 15x7 with 215 for the track i want to get an extra set of wheels and tires for the back only. what size will fit under the rear wheel well. i'm hopin to get a 15x 10 rim but if 15x8 is all that fits that fine. i was wanting to run the MT drag radials on the wheels. also whats the largest diameter you can fit about a 28 or 29 inch on a stock rear end?
Old 01-30-2007, 10:58 PM
Red92RS's Avatar
Car: 1992 Camaro RS
[QUOTE=1989GTATransAm;3208725] Red92RS what is a very good performance tire for the street with the 16x8" rims on my GTA? I have upped the horsepower so much now that traction is a big concern on the street. I use the MT ET Street Radials when I go to the track and hope they still hold. [QUOTE]
Well, I have BFGs KDWS tires because they have really good wear compared to most performance tires and are a decent price. Now I have a built LS1 so if i get on it I roast the tires. The most popular BFG performance tire I sell is probably the GForce KDW NT( NT stands for New Tread because these have a flame like design where the TT or traditional tread looks like a normal tread design). They get outstanding wet & dry traction also, I will probably buy these after my tires wear out. By the way I am running 275/40zr17s all the way around on 17x9.5 in wheels.
Old 01-30-2007, 11:04 PM
Red92RS's Avatar
Car: 1992 Camaro RS
I would think unless u have a high hp engine a 15x8 in wheel would be fine. You could probably go with a 275/60R15 drag radial. Everybody should know that if you put a taller tire on the rear of your vehicle on a street driven car it will cause your speedometer to read incorrectly and that could lead to an unexpected speeding ticket, but for the track obviously it wouldn't matter because it only matters how fast you were going on your time slip. If you want to fill up your wheel well I would suggest lowering the vehicle, I have Eibach's Prokit and believe it looks alot better than stock.
Old 01-31-2007, 10:54 AM
Car: 1989 GTA
Engine: 369 TPI
Yep, that is my problem. I'm roasting the tires big time. So much so that it is now a safety factor. So you recomend the GForce KDW NT tires. Thanks I will give them a good look and most likely go with them. Hopefully they have the 255/50/16 versions. Thank you for the information.
Old 01-31-2007, 05:24 PM
Red92RS's Avatar
Car: 1992 Camaro RS
I don't see them in that size, only a 245/50R16
http://www.bfgoodrichtires.com/specs...-a-kdw/22.html
Old 01-31-2007, 08:35 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I went with Sumitomo HTR-H4 235/55HR-16 on 16x8 IROC wheels on my '83 Z28.It's the same size that came on IROC and then Z28 convertibles.MY CFI 305 doesn't give me a real problem with traction off the line but they do provide excellent responce.These are all season tires but I don't drive her in the rain so i can't attest to wet traction.
Old 01-31-2007, 09:04 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have seen 295/50/16, tiiiiiiight fit, looked great, dont know how it rode, my 295/50/15 fit and ride geat on my 8.5 wide wheel.
Old 01-31-2007, 10:46 PM
Car: 1989 GTA
Engine: 369 TPI
The 245/50R16 tire may be the way I go. The GForce tire looks pretty good. With a 300 rating it might well do the trick.
The 295/50R16 tires may be a little to much. From what I have read the fender wells would need some work. I don't want to do that. Thanks guys.
Old 02-01-2007, 12:16 PM
Car: 86 Camaro
so if i buy an 15x8 rim what would you reccomend the offset to be? the rims now are 15x7 with a 4.5 inch offset maybe 5 inch or something?
Old 02-04-2007, 03:56 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
There's a good article in Chevy High Performaance this month on "Drag tire Tips" for those interested in learning a bit.
Old 03-23-2008, 05:46 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Tire Size
Just put 295/50-16's on the back of my 92 equipped with stock 16" wheels and thin stock rear spacers, just had a minor amount of rubbing that was quickly fixed with a few blows of a rubber hammer, I'm not getting any rubbing at all now even during hard turning. I enclosed a few pics of where it was rubbing and the car fitted with the tires.
Attached Thumbnails Tire Size-rub-passenger-side.jpg   Tire Size-rub-driver-side.jpg   Tire Size-92-camaro.jpg
Old 03-23-2008, 10:15 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Re: Tire Size
Who makes the tire? What speed rating do they have?
Old 03-23-2008, 10:47 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Tire Size
Cooper Cobra Radial GT, the front 235/55-16's have a T rating and the rear 295/50-16's only have a S speed rating, that's faster than I intend to go.
Old 03-28-2008, 05:04 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: Tire Size
Man that's the widest tire I've seen anyone put on stock 16s.Do they rub on bumps at all?Not on the sides but on top.
Old 03-28-2008, 07:01 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Tire Size
I've had no problems yet, but stuff a few fat chicks in the back and you may have a problem
I might roll the wheel well for more clearance if needed. Check the pic out, seems to be enough room to me.
Old 04-02-2008, 12:36 AM
83 Crossfire TA's Avatar
Re: Tire Size
There’s a few people out there that have run that size successfully. With stock backspacing rear 16’s they should fit pretty well, I tried a set on some 1/4” offset TT2’s (which puts them out almost ½” further) and I was worried that they would hit a little forward and rearward of the centerline on the outside fender lip, but I didn’t really have any problems, and this was on my formula with eibach springs on it.
Old 04-02-2008, 12:46 AM
Re: Tire Size
I found a couple of pictures...
Attached Thumbnails Tire Size-tt2_05-05-02_2m.jpg   Tire Size-tt2_05-05-02_5.jpg
Old 04-02-2008, 11:42 PM
92RS702's Avatar
Car: 92RS
Re: Tire Size
Those tires look nice I wish I knew I could put a tire that wide on my stock 16s and still fit them on my car before I bought my new tires 2 months ago.But at least I got an excuse to do burnt outs more often,so I can get new wider tires on the rear.One last thing how happy are you with the cooper tires,compared with other tires you've had?
Old 04-05-2008, 08:45 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Tire Size
I've gone through 2 sets of Cooper Cobras since I bought the car new in 92 and am on the 3 rd. set now, + the Original set of Crapyear Eagles that were on it new, they sucked badly in wet weather. The cars got almost 200,000 miles on it so I would say I like them.
Old 04-06-2008, 01:25 PM
tuned-z's Avatar
Re: Tire Size
i have a pair of 315/40/16 michelin xgtz tires for sale, new/never been mounted. $200.00 + shipping from michigan. contact me at
delysid@comcast.net
Old 04-09-2008, 02:02 AM
Bs88ta's Avatar
Car: 88 pontiac trans am,79 z28
Engine: 350,350
Transmission: 700r4,th350
Re: Tire Size
so what's the widest aftermarket rim and drag radial that will fit without rubbing.i'll have a 550 hp engine installed in the coming months,and traction for the track is a big concern.not right away,but first of the year i'll be getting and installing a strange drag rearend in the 88 t/a and would like to go with a 15" and around 10"wide rim and tire combo.on the street i'll be running the gta 16's and not really hopping on it.but on the track,i want to hook and go.probably instaling a bigger roller cam and going around 600hp,then comes spray.needless to say it's not gonna be a mildly modded car,so looking to get everything out of the room i have.rub on take off is a serious problem,i'm thinking it's really gonna comedown hard in the rear on take off.so how tall and how wide in a drag car that is not tubbed.if i can't do that,would a small mini-tub in the back get me what i want?
Old 04-09-2008, 02:30 AM
Stephen's Avatar
Car: 87 GTA
Re: Tire Size
Right now, we have 2 threads going discussing the very same matter...
https://www.thirdgen.org/forums/susp...ml#post3692593
Old 04-21-2008, 10:07 PM
frosty44's Avatar
Car: 1991 z28
Engine: unknown at this time
Transmission: auto
Re: Tire Size
i am a fairly new member here, but my question is can you run 18inch rims on a stock 91 z28 body? i was thinking of running18x8 rims with 245/45zr18
will they work on all four corners? or is 17 inch rims the best way to go?
Old 12-25-2008, 12:30 PM
1985Z28camaro01's Avatar
Car: 1985 Pontiac Firebird Trans am
Engine: 305 V8 4BBL (LG4)
Transmission: T5 non WC
Re: Tire Size
i just bought a z28 and i want to know the summer tires that i can buy for my stock 15x7's that are reasonably priced because I'm on a strict student budget!
Old 12-25-2008, 04:51 PM
shibbykins's Avatar
Car: 91 RS Vert.
Engine: 350 TBI cammd
Re: Tire Size
moved question
Old 05-08-2009, 07:31 AM
Maladroit's Avatar
Car: I'm looking for a nice IROC
Re: Tire Size
The secret is to keep the tire height and revolutions per mile aligned with your speedometer.
If your tire is too tall, then you are going faster than your speedometer indicates: "Please pull me over for speeding?!"
If it's too short, then you are adding needless miles to your odometer, which depreciates your car a lot.
For easy tire and wheel conversion ratios, go to http://www.net-comber.com/tirecalc.html. Whoever created this calculator did an excellent job.
Be sure to look at ride height too, why raise your Camaro higher? Even a half-inch causes incredible losses in handling.
I am a former BFG Certified TA Specialist (factory-trained, blah, blah, blah...)
Old 05-09-2009, 03:55 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Tire Size
this is what i have on my 1986 camaro. on The rear it is 295/50/15s and on the front 195/70/14s. I do have a little problem of rubbing but that was b/c i had bad air shocks. which i just replaced and worked out great and my opinion looks nice.
Old 05-09-2009, 09:02 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Tire Size
i have a 90 camaro and using stock 15 inch rims 255/60 15 is the best i an do for the front and 275/60 15 for the rear. if i had used the 50 serise the front would have scraped during turning - hope that helps. pics on my site and i went with firestone because they had good tread with compared to just wall to wall width. and since i am not racing it did not matter that i could only go 112 mph - i never go that fast anyway.
Old 05-18-2009, 04:59 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
Re: Tire Size
ive got 245 45 16's on mine they look stupid, i want some big fat tyres, what is a good fat size for the back, can you change the profile from 45 to 60 or 70?
Old 05-18-2009, 10:17 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: Tire Size
i'm stickin with stock i've had soo many probs with speedometer... right now i'm 10 mph off. It sucks... trust me too much math to drive...
Old 06-20-2011, 01:51 PM
  #42
87IROC198Z's Avatar
Car: 1987 Iroc-Z
Engine: 406 SBC
Re: Tire Size
I recently picked up a set of 2002 camaro ss wheels (17x9) and am running 2inch spacers all the way around. Im suggesting using 255/45/17's all the way around. I would use 275's but im worried about how well they will react to hydroplaning and they only make a 40 size sidewall in this size. recommended sidewall for a 17 inch wheel is 45 to keep the speedo on. Anyone have any recommendations for me or should I stick with the original plan of 255/45/17's? Thank you!!
Old 06-20-2011, 09:08 PM
  #43
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Tire Size
keep in mind the 40 sidewall is just a ratio of the width, its not a direct measurement of height. For instance, my front wheels have a 40 sidewall and the rears have a 30, but the rear sidewall is actually taller than the front wheels because they are so wide.
hydroplaning and the resistance there-of, has a lot to do with the tread design, not necessarily the width.
i would do the 275 on the rear and the slightly narrower on the front, you can use the 275 up front, but the car will generally require more steering effort and may follow ruts and such in the road more than a narrower tire would.
Old 06-20-2011, 09:18 PM
  #44
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Tire Size
I switched to 275/17s a few years ago & totally forgot it that!
When I put them on, the car darted left & right, or so it seemed at the time. No reading somebody mention the wandering, I realized that I cannot really the last time I thought about it doing that. Either it has become so "normal" to me that I automatically compensate for it & give it no thought? Or it plain just wasn't as bad as it felt to begin with. It probably wasn't really that bad after all.
Old 01-15-2012, 05:49 PM
  #45
Da11asC0wboys's Avatar
Re: Tire Size
I have a 92 rs my problem is the guy I bought it from thought low pros were cool or something on 16s and he lived in the city I live in the country and I just ripped of my new exhaust and it bottoms out every like bump I was wondering what is the widest and tallest I can go all the way around and have good clearance
Old 01-20-2013, 09:39 PM
  #46
CoryDon007's Avatar
Re: Tire Size
i have read several places that the biggest tire that people have been able to fit in there third Gen Camaros' are these specs.
Front:
Wheels: 17” x 8” w/4-½" backspacing
Tires: P255/40ZR17
Rear:
Wheels: 17” x 9.5” w/5-½" backspacing
Tires: P285/40ZR17
Old 05-20-2013, 03:05 PM
  #47
Chad31's Avatar
Re: Tire Size
Will 205/60 r16's fit an 86 camaro without rubbing?
Old 05-20-2013, 03:09 PM
  #48
Car: GTA
Re: Tire Size
Depends on your wheels backspacing. Do some looking around on TGO before asking & you'd find the answer without posting your question in somebody else's thread.
If you need to ask somebody then do the courteous thing start your own thread instead of putting your question into somebody else's thread.
Old 05-20-2013, 06:33 PM
  #49
Chad31's Avatar
Re: Tire Size
my fault im new to this forum thing
Old 09-21-2013, 02:12 AM
  #50
Chris Reese's Avatar
Car: 86 Camaro Z
Engine: 305 tpi...
Transmission: 700 r 4
Re: Tire Size
Stock is p215 65 15
Quick Reply: Tire Size
