Firebirds for Sale Post your Firebird for Sale.
1989 trans am GTA roller built suspension check it out
Old 05-06-2015, 07:20 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Selling my trans am as a roller. It is a 1989 GTA with lots of extras.
Interior consists of:
8 point rollbar
Front leather seats 98-02
02 ws6 dash swap
Dynomat on firewall
New headliner
Power windows
Gt grant steering wheel
Tinted windows
Proratchet shifter
Battery mounted in trunk with terminals on rear bumper
Exterior:
Metallic blue paint job in ok shape
Ram si 2 hood with functional scoops
Fiberglass wrap around wing
T tops
17" ws6 chrome wheels with new tires
Suspension:
Front tubular cross member
Tubular control arms
Ls1 front disc brake conversion on from
Lakewood 90/10 shocks on the front
Lakewood 50/50 shocks on rear
Aftermarket rear lower control arms with relocation brackets
Driveshaft safety loop
Tubular adjustable torque arm mounted on transmission mount
Transmission mount fits th350/th400
Dual intank walbro fuel pumps ( I used to run one on a boost switch)
-8an feed and return fuel lines
9 bolt rear end with 3.45 gears with disc brakes on the rear wilwood adjustable proportioning valve and ls1 master cylinder
Radiator support has been moved forward two inches and down two inches .custom aluminum radiator and dual derale fans included
Custom fabricated tubular front bumper support
All the tie rods pitman arm idler etc have no play front wheel bearings have no play rear is in great shape it was aligned before taking it apart. I will only send pictures to serious inquiries please don't waste my time
Price is $2500 including an aem uego wideband gauge and sensor, boost, oil pressure volt and temp gauge all auyomete brand. I have them in the air vents in the dash
Also have a swing out arm kit which is not installed to go with it.
CLEAN VIRGINIA TITLE.
I'm 15 minutes outside of richmond.
Give me a call or text at 804 516 2197 don't waste my time
Old 05-10-2015, 11:06 PM
Dreamcamaro91rs's Avatar
Car: 1991 camaro rs 305/auto, hardtop
Engine: BUILT LQ9
Transmission: 6speed
Axle/Gears: 12 bolt moser
Re: 1989 trans am GTA roller built suspension check it out
Man......... Why the fawk does all these deals have to be so far away. I woulda bought it as a complete car if I had of seen it when you had it listed. I'd even buy it now but doubtful anyone would take on the hassle of shipping a rolling chassis to Canada. Good luck with the sale dude. That's a sweet deal.
Old 05-14-2015, 02:21 AM
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
Post pics i'm sure it'll be gone in a hot second, then.
camaro11j
09-19-2018 08:49 AM
84z96L31vortec
08-20-2017 12:16 AM
kyleb24
08-15-2015 08:24 AM
gta power
08-13-2015 06:15 AM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 1989 trans am GTA roller built suspension check it out
