FBI CAMARO RS B4C
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: FBI CAMARO RS B4C
Interestingly NO 1LE
1G1FP2382ML196894
Vehicle: CAMARO RS 2 DR
Year: 1991
Build Date: 1991-07-02
Found 89,578 vehicles matching that year and model in our database.
RPO Description Matches
1AA SALES INCENTIVE - RETAIL AMENITIES -- DELETE 4,071
1AZ ORDER MODIFICATION - ORDERS SOLD 8,245
1Q8 VEHICLE INSPECTION - GSA FORM 1398 166
1SA PACKAGE-OPTION 01 (1SA) 5,524
17P WHEEL COLOR-SILVER (17P) 50,869
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW) 7,975
7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW) 7,975
75Q MOLDING COLOR-BRILLIANT RED METALLIC (75Q) 8,383
75U EXTERIOR COLOR,PRIMARY,BRILLIANT RED METALLIC (75U) 8,892
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 43,060
82B TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82B) 21,944
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 52,890
829 SEAT BELT COLOR - MED DK GRAY (829) 52,890
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 43,060
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 89,578
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 89,578
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 56,960
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 55,374
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 64,379
B2L ENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L) 5,956
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34) 83,850
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35) 83,850
B4C PACKAGE SPECIAL SERVICE POLICE PKG(B4C) 403
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84) 84,227
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 55,564
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 86,405
DG7 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7) 20,287
D27 COVER,REAR COMPARTMENT STOWAGE LKG RR LOAD FLR(D27) 53
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42) 55,813
D5X GEAR-SPEEDO DRIVEN (D5X) 5,956
D8I SENSOR-VEH SPD (10456089) (D8I) 5,405
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80) 77,424
E5Z ADAPTER - SPEEDO - DELETE 89,578
E9Z KEY - SPEEDO - DELETE 89,578
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2) 9,285
GAM VEHICLE - GOVERNMENT (G.S.A. SALES) 166
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 33,702
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 12,751
IPB TRIM,INTERIOR DESIGN (IPB) 37,221
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65) 4,881
KC4 COOLING SYSTEM,ENGINE OIL(EXPORT-IRAQ) KC4(EXPORT IRAQ) 7,068
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 55,334
K68 GENERATOR,105 AMPERE 105 AMP(K68) 12,557
L98 ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98) 5,956
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 75,616
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0) 75,616
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 78,845
NK3 STEERING WHEEL,SPORT,SOFT RIM,SIMULATED LEATHER(USED WITH EUROSPORT B2T) SIMULATED LEATHER STRG WHL(NK3) 77,189
N10 EXHAUST SYSTEM,DUAL(USED WITH TOURING YP6) D/EXH(N10) 7,068
N64 WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64) 4,929
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96) 44,795
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC) 9,285
R6V CONTROL - SALES ITEM NO. 21 43,415
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3) 89,578
UN6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK(EXPORT) STEREO CASSETTE(UN6) 77,719
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 88,820
U79 SPEAKER SYSTEM,4,DUAL FRONT COAX,DUAL EXTENDED RANGE PACKAGE SHELF 4 SPKR SYS(U79) 82,582
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 89,578
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 81,034
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 88,169
Y86 CAMARO "RS" PACKAGE(MERCHANDISING OPTION) RS PKG(Y86) 77,424
1G1FP2382ML196894
Year: 1991
Maybe I missed it, but no mileage listing. It'll be interesting to see how it does, and I'd love to see the paperwork on the car.
My B4C is this way - no 1LE. However, the previous two owners were thoroughly convinced that it had 1LE. The RPO codes determined otherwise...
I'm assuming the post-FBI owner added the stripes?
I thought for some reason that in 1991 the 1LE was a little more common on the B4C than that... I know not all of them got the brakes, but I thought it was higher than just 13...
Learn something new... Be better if it did.
What makes this really interesting to me is this:
Camaro 1LE (White Book)
1989 - 111
1990 - 62
1991 - 478
1992 - 705
In 1992, all of the B4C cars (to my knowledge and understanding) had the 1LE, and there was 589 B4C cars... Which leaves only 116 1LE w/o B4C... If my understanding and information is indeed correct, then why were there so many 1LE's in 1991, but not as many other years?
1989 - 111
1990 - 62
1991 - 478
1992 - 705
Transmission: 5-Speed Manual
Because According To This Article Enthusiasts And Dealers Were Becoming More Aware Of The 1LE,That's Why The Big Increase.
....and it was the longest production year of any f-body ever produced. 1991 Model year started January 1st, 1990 and ended August of 1991 - 20 months of production. Cars with the new body panels could be used in the 1992 season and with the 1993 models coming out with the new generation, there was little need for a 1 year car.
Of the 13 produced, 10 of them were 5.7/auto models and 3 were 5.0/5spds.
I wasn't doubting it, but it just makes me scratch my head
I'm actually surprised that 62 of the 1LE's got built in 1990. Lets face it, you knew the IROC association was going away, there would be a new look and they would be dated almost as soon as they were delivered. Pontiac only built 4 of them & I know for a fact that 2 of those 4 soon wore the new panels.
The new panel thing I think was common back in the day, probably still today. Why buy a new car when you can race your old one for a whole lot less? Swapping pieces and parts would take a few hours at the most, and I might be wrong, but it seems that if it was something like Players or Firehawk you might have had to be racing with the latest style changes. I liked what the owner did to your Trans Am, make it into a Formula and ditch the bulk, it would make it faster and less costly to repair if it got damaged.
1 Post
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
"I liked what the owner did to your Trans Am, make it into a Formula and ditch the bulk, it would make it faster and less costly to repair if it got damaged."
Notice how okfoz boosted up the Formula owners and sucker punched the T/A guys, LOL.
Formulas
1) Perform Better
2) Look Better
3) Less Bulky
Conclusion: Formulas are better
1) Perform Better
2) Look Better
3) Less Bulky
Awesome! I'd be very happy with $22k for my B4C.
I think auctions are the best way to get top dollar for these cars when selling.
20k hammer plus fees.
The car showed really well in a sea of crappy restorations and over-fluffed junk cars! It was a night and day difference comparing it to the majority of the cars there.
Sandra & I were there for about 6 hours yesterday and were very disappointed in the way they orchestrated the event. I think the facility was overwhelmed by the number of people that attended and they oversold it. It was poorly organized and poorly run & when we first showed up weren't even allowed into the arena because it was over full! The venues outside were neat and you had good access to the cars before & after but the distances to & from were pretty substantial and the maze that's designed to keep you in a casino did not lend itself well to an event like this.
Purchased by a guy with more money than brains......
Me!
Typical case of it was "just like my first car" expect my first car of course had the 2.8 V6 because I couldnt afford the insurance on a V8.
I know these cars aren't really worth this much money but in the Northeast in particular nice ones like this really don't exist....
Me!
Me!
Me!
There are good cars in the Northeast, you just need to be willing to look.
I've always felt that going to check out a car was like going on a blind date. Once you get past all of the lies and the old pictures you occasionally find one you want to bring home.
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
Me!
Me!
I agree, but it's a catch-22... first, because some people prefer the better 5.7L TPI. Second, because the 5-speed is hard to keep the mileage off. I bought my B4C with 11k miles on it about 6 years ago, but that LB9 T5 combo is so much fun that I'm now over 25k miles. When I bought it, I drove it 1000 miles home instead of shipping. Crazy, but fun!
I didn't realize this FBI car had 13,000 miles on it.
Congratulations on the car! Price seems right given the mileage, options, and documentation. Also, it sounds like you were in a bidding war with some other people. I think it revealed the true market value of an excellent B4C.
Me!
Me!
Honestly I really like the paint the Red with the silver stripes to me looks really really good. Granted it kind of kills the idea that the B4C is a sleeper, but I would definitely drive it.
Honestly I like the White Johnson phantom next to the B4C in that pic., I would paint it Red and Black and call it the Menace... The Phantom Menace... Just kidding.
First and foremost that particular Barrett Jackson was a seller paradise.
I was hoping to by two or three other cars and they went wayyyy over market price. 20K hammer was my absolute top on this car and I didn't think I was going to get it.
The paint on this car is spectacular though I guess original would be preferred for such a low mileage B4C.
I guess my real gripe is Barrett Jackson makes no effort to help out the buyers vet the cars.. I know it's not in there best interest as all it would do is lower the prices and therefore reduce their income. But the owners are not required to be at there cars at anytime to answer questions....you can't start the cars or check if anything is functional...yes I know if you don't like it don't bid...
but either way
Examples of thing I didn't expect to have to fix on such a "mint example"
Brakes:
Went to drive the car up on my trailer and depressed the brakes and it made a HARD left turn... ok frozen caliper no biggy...I already replaced both front calipers and its perfect now......but the car was completely non-drivable prior to the fix.
AC not working (again no shocker there but still disappointing ill sort it out soon.
Tach not operating.....Already ordered a new control board
Water temp gage not working
SRS light on
Headlight Switch broken...the typical plastic nut issue...already ordered.
but either way
Brakes:
SRS light on
1 Post
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
I wonder why a gov ordered FBI car with legit GAM rpo was not driven? Was the car rejected by the bureau for some reason. The '91 I owned was loaded with switches and mods from service. I assume no mods on this car?
Engine: L98, LT5
My friend said he knew the history of it, it was a training car and why the mileage was low. It did have a cage in it at one point as you can see under the dash corners where it is patched up and it most likely did have all of the switches and other equipment which were eliminated when the car was restored.
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
A friend of mine has the identical car (91 B4C in that color) and was on the floor at the auction bidding on your car as well. There was another lady near him also bidding on it who was seriously interested in it. I spent quite a bit of time climbing around it in the parking garage, it's a good car and will continue to appreciate in value. Whoever painted it did a nice job and i'm sure spent big bucks to get it done. I think you did good! Not sure where you are from in New England but there are plenty of good cruise nights in MA, NH, and CT. Maybe we can all catch up at one this season!
I saw the car at the auction and did bid for a while. The lady sitting at the end of my row came within $500 of grabbing this one. It would be great to see this car out this summer.
If you read post # 653 you will see my car: https://www.thirdgen.org/forums/hist...1992-a-14.html
Correct me if I am wrong, but this is the same car which was for sale here right? I believe PurelyPMD looked at it prior to going to Barrett Jackson.
https://www.thirdgen.org/forums/cama...-b4c-very.html
#42
I really wanted the Red Porsche 912 it was a solid driver and was worth ~40k
If memory serves me it went for $68K + 6,800 premium for an outrageous total of $74,800
There was also a non numbers matching light blue 63 Corvette coupe with aftermarket air that was again a really nice diver. Probably worth $50-60K that went for over $100k with the premium.
I was also going to pick up the ex-bonderant mustang school car...Orange.. for a track day toy. i passed because it crossed the block very early Thursday and i wanted to save my money for the other cars....it would have been a lot of fun and went for 14,300 with the premium.
the prices were in general totally silly.
As far as my dream build i want a third gen with a perfect body, stock interior, LSX T56 great suspension and brakes with A/C... and no T-Tops. It should look as stock as possible
#43
I was up there on Friday; I was truthfully very disappointed in the quality (or should I say lack of quality) of the vast majority of cars present. Cameras and TV hide a multitude of sins; don't be fooled, many of these cars were flat out rough, sub-par, well-worn and poorly restored, used cars.
I wish you luck with your new purchase, however.
#44
Engine: L98, LT5
#46
Car: 89 gta...91 b4c...06 hemi ram..
Engine: 5.7 in all 3...pontiac/chevy/dodge
Transmission: auto
Axle/Gears: 3.23 and 3.73
I thought i bought the last evoc 3rd gen fbi b4c camaro from Quantico in 2007....same identical car but mine had 23k miles when i bought it and 10yrs later now just 24k miles...
#47
Car: 88 GTA
Engine: 5.7
If I remember correctly, FLETC in Georgia had Camaros as well for their driver training. By the time I went through the training in Virginia, those had been retired.
breathment
08-09-2002 11:51 PM
