New Conteur camaro interior....pics inside
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I figured I'd post this up here too since a good portion of you probably don't visit the history section very often. I have a post over there as well dealing with the history of these interiors.
https://www.thirdgen.org/forums/hist...o-conteur.html
But enough about the history. Here is my interior.
last one is in the garage with the flash so thats why it looks a bit weird.
Engine: 355 TPI
Re: New Conteur camaro interior....pics inside
45 views and no replies? no one like?
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
It looks good. The only thing that's left me going humm...is the Camaro overkill on the seats. I guess I could get use to seeing it
Engine: 355 TPI
I got the material from John (John in RI). Hes got about two interiors worth of it left along with some of the 83/4 brown material.
As for where i got it done, I got it done by John at A. Supreme Auto Upholstery and Glass in Windsor Locks CT.
Engine: 355 TPI
Thanks Too bad my camera does not do it justice. The black on the seats is much darker than is coming through in the pictures. I need a better camera.
Car: 2011 2LT RS
I like it alot! Although your seats look different than the 3rd gen seats I'm used to seeing. Looks as if you added a front bolster to where you sit?
Engine: 355 TPI
Nope thats the style of these seats. Drivers seat has 18 different adjustments. I did a pretty big writeup on them in on the history board (its stickied ) The only mod that i did was changing up the color combo on the seats. Otherwise i followed the factory patterns exactly..or should i say i had my upholsterer follow the factory patterns exactly.
Looks good man! Maybe instead of the Camaro wording... IROC-Z would have been way cool!
92camaroJoe
08-13-2015 06:07 AM
