Gauge Cluster Blues
Old 10-18-2016, 05:20 PM
MadRomeo's Avatar
Car: 1985 IROC-Z
Axle/Gears: 3.42 Auburn POSI from a '96 Z28
Gauge Cluster Blues
Hi,
I'm new here so I hope I'm doing this right...
So I have an '85 IROC that I just bought and I was doing some work on the cluster and I followed another thread on how to do it the right way as my Hanes manual didn't do anything for me.
As I went to put it back in, the left side(speedo) stuck out about half an inch and won't go back in....
The tach side goes in fine.
Any help would be appreciated.
EDIT: The steering wheel is also making clicking sounds when turned either direction, maybe a short????
Old 10-21-2016, 10:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Gauge Cluster Blues
Probably didnt re-connect the speedo cable, maybe.
Old 10-22-2016, 10:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Regarding the speedometer; if the cable is connected properly, open the hood and find the cable as it passes through the firewall and pull it towards you a bit. This should pull the cluster back into place.
Do you hear the clicking sound with the turn signal lever in its neutral position or when the lever is up or down?
Old 10-24-2016, 11:23 AM
MadRomeo's Avatar
Car: 1985 IROC-Z
@84 1LE I got the gauge cluster back in. Thanks!
@paulo57509 The steering wheel clicking was a grounded out cable for the horn. The horn is broken so it just kept clicking.
I really appreciate the help guys.
