Swaping LT1 1993
Old 08-23-2006, 09:36 AM
  #151
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Originally Posted by Jamie55
mat89Rs I hope you got my message on ur question about Speed Den or MAF. I am new here to this forum and to the world of Chevy's. I got a great deal on a 1994 Z28 just this last weekend so I will be asking alot of questions about how to squeez more out of my Lt1 on the cheep for now. I was a die hard ford fan all my life. I still own a very rare 1994 Ford Mustang GT R Code Steeda Edition. Fast but I have always loved them F Bodys. Jamie55
Had you looked at the date of the thread, it was over 5 years ago when he put up that post.
Old 09-27-2006, 10:49 PM
  #152
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
WOW this post has been dug up from the depths of tgo! At least he used search feture.
welcome to tgo!!
Old 02-18-2007, 02:46 PM
  #153
SlowCamaro88SC's Avatar
hey Pete did you get new headers what about the EGR can it block off?? from back of intake do they sell a cover for it? and where can I get one , my swap is 94 vette LT1 and 4L60E into a 86 Iroc thanks and what the speedometor would I have change it? to electronic what did you do your thanks again
Old 03-11-2007, 10:25 PM
  #154
XxSgtReillyxX89's Avatar
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
hey guys i got a 94 LT1 and I'm looking to drop it in my 91 3.1 Firebird I'm wondering would it bolt right up to the stock mounts or is their modification needed for the extra 2 cylinders? Do i need a new k-member i know i need stronger struts and shocks. the engine is out of a Impala SS. I just wanna get it in there without much frustration and confusion. i got lost with the resistance and the VAT and MAF please someone help my parents don't even know i got this engine lol I'm only 17 and I've done engine swaps before but i never put in a bigger engine before i only swapped out for the same motor
Old 04-07-2007, 10:17 PM
  #155
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
Re: Swaping LT1 1993
I have a 1990 Camaro RS with the dog 305 TBI with 237,8xx original miles on the engine and I'm going to be looking to drop an LT1 from a non-Police Chevy Caprice in my 3rd gen Camaro. So, obviously I have some questions/points for the knowledgable here.
  • I understand that the LT1 will directly work with the stock engine mounts.
  • Will the auto tranny from the Caprice fit my Camaro? Or do I need to grab a 4L60E from a 4th gen F-body--and will that fit.
  • Someone told me about the "reverse cooling" on the LT1 that needs to be re-engineered--anybody know of any guides how to do this?
  • I'm planning a custom dash+console with a completely custom instrument cluster--so that means I won't be using my stock instrument cluster from my Camaro. Is this a problem--or will that just make it easier in terms of the wiring.
  • Will I have to relocate the A/C compressor--or can I just add a "delete" pully?
  • What else will I have to relocate/fabricate/re-engineer on the LT1 for my 3rd gen?
Thanks in advance for any assistance on my project.
Old 04-30-2008, 11:15 AM
  #156
slickvic's Avatar
JUST A QUICK QUESTION.. CAN I USE THE SAME CLAM SHELL THE 1994 LT1 BROUGHT FOR THE A/C TO MOUNT MODIFICATION? (ON A 1988 CHEVY CAMARO) THANKS VIC..
Old 09-09-2009, 03:21 PM
  #157
musclefirebrd13's Avatar
Car: 1990 pontiac firebird
Engine: 305 tbi
Transmission: not sure, trying to figure out
first time ever posting on here not sure were to start or look, but i'm looking to buy a 1996 or 1998 firebird formula with an lt1 to swap out the tranny and lt1 into my 1990 firebird, i was wondering if it would fit without any fabrications needed, or what i would have to do to get them to fit? I won't be doing it myself i was just wondering if it would all fit ok or if i should go another direction, and also how hard and much would it cost to go from my auto trans to possibly a 5 or 6 speed trans?
Old 11-21-2009, 07:51 PM
  #158
Zdrrguy's Avatar
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
I have some of the same questions as well, I have everything from a 95 including the k member.
Thanks Mark
Old 01-01-2010, 02:21 PM
  #159
3rdGenFreak1227's Avatar
Car: 86 IROC Z
Engine: LQ4
Axle/Gears: 4th gen 10 bolt 4:10
Hey guys first of all I just wanted to thank everyone for their very helpful information on this swap!
I just bought an 87 Trans Am with a junk *** bone stock 305 4BBL in it...needless to say I'm not at all impressed with it. So I have decided to swap an LT1 that I'm getting for a decent price along with the stock ECU and harness. I mainly bought the car for the cleanliness of the body not for the motor. I went to school at wyotech and am very familiar with the sensors and what they do and what ranges they need to operate in so I think I have a little bit of a jump start on this (atleast I'm hoping lol). Here are the ?s I have...i apologize if I'm asking redundant questions and appreciate your patience on the issue.
1. If no air conditioning...physical fitment of engine shouldn't be and issue and should just bolt right up correct?
2. VATS module..if I do not have the vats module that was originally in the donor vehicle is there a way to trick it? I have the ability to get resistors and solder them in...just need to know which ones...if it all possible I would like to just disable VATS completely
3. Are there any extensive mods that I need to do to the stock LT1 harness to get it to work correctly? Also does the LT1 ECU mount underhood (like LS 4th gens) or in stock 3rd gen location?
4. Also as far as converter clutch wiring goes in the trans can I just splice converter clutch engagement wires from LT1 harness to the stock connector on the 700r4 trans and get the converter clutch to operate normally?
I'm sure I will have other ?'s as this goes on but if I could get these answers before I begin the swap it would help greatly to atleast get the thing to crank lol
thanks again guys!
Old 01-10-2010, 12:09 AM
  #160
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
Originally Posted by Z28ricer
Hey Mat currently im doing the same swap into my 86 Z28, depends on if you want to keep the A/C when you swap for fitment if not you can get an a/c delete idler or i have heard of removing the back half of the compressor, without the compressor it bolts right in using the stock mounts, with it you have to mod the pass. side mount a little, i would also recommend that you get an aftermarket harness due to other things that you may delete when swapping, painless has one for the 92-93 LT1 its like $350 from jegs, you will need to fab fuel/a.c/power steering lines and radiator hoses.
what if you already have a tpi and you just want to out the lt1 in?
sorry im kinda still new to this
Old 11-04-2010, 04:10 PM
  #161
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Originally Posted by TonyC
The engine will fit in perfectly, unless it has air conditioning. If you do want air conditioning there are a couple of options.
1. Contact S&P or March and get a new serpentine pulley kit to mount the A/C up top
2. Section the motor mount as shown here
www.hpsalvage.com/3rdgen.htm
You will need a different fuel pump (electric). SLP's headers have worked for many people on LT1's. The painless wiring harness is highly recommended for ease of installation, it's part # PRF-60501 in summit and is $350, it specifies a reprogrammed prom. Hope this helps.
if it was only 350 i would be all over it1
http://www.summitracing.com/parts/SUM-890121/
Old 12-26-2010, 01:13 AM
  #162
92last1rs's Avatar
i am new to the web site and owning a car all together. i have a 1992 camaro rs with the 5.0 and i am looking to buy a 1995 impala ss that is junked that has the LT1 5.7 li engine. What should i know? Any info at all would be great. Will it fit?
Old 12-26-2010, 01:14 AM
  #163
92last1rs's Avatar
Need info on a 1995 impala ss lt1 swap for my 1992 camaro rs 5.0 li. Any info at all would be great.
Old 12-26-2010, 03:25 AM
  #164
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Its no different than swapping in an F-body LT1, other than you'll have iron heads vs alum, and iirc they dont have vats to contend with.
All of the swap info is here, you should be able to search and find virtually anything, the swap has been done countless times since the first few of us got started back in late 90's/2000 lol.
Old 01-10-2011, 04:49 PM
  #165
xler8ted's Avatar
Re: Swaping LT1 1993 heads, cam 383??
Please put me in the right direction!! I have a 93 lt1 vette and a conundruim...Should I throw heads and a cam on the lt1 or pick up a 383 stroker making 385 hp. The lt1 is stock at 300hp with 49k...I need to know whats gonna be the way to go!! thanks.
Old 06-09-2014, 10:09 PM
  #166
squidmaster408's Avatar
Car: 1982 z28
Engine: 350 tpi v8
looking for 1993 camaro wiring harness diagrams
Old 10-05-2014, 09:08 PM
  #167
brynorrislt1pro's Avatar
Plug the lt1's opti hole. Drill a hole in the lt1 intake put the 305s dizzy in it. Delete the a/c. Use the lt1 radiator and wire up the fans. You guys are making this so much harder than it has to be. This doesn't even involve a trans swap... Google hei lt1 and for the love of god you can not use the 305 manifolds. The lt1 has D shaped ports they aren't even close
88SS6SPEED
11-11-2015 07:05 AM
L0tuS
10-04-2015 08:07 AM
WejaZ28
10-03-2015 07:38 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
L0tuS
09-04-2015 11:16 PM
Quick Reply: Swaping LT1 1993
