Spohn Problem
Spohn Problem
Ok so i have a Spohn K Member and i had two problems, the first was not being able run A/C in factory location got that fixed,but the k member and engine dont sit level with each other. Any ideas on how to correct the problem? I added spacers in between the block and the passenger side engine mount thats seemed to help a little but it spaced the kmember out more than it pushed it up. Any ideas would be much appreciated.
Car info:
87 Z28
2002 Ls1
Spohn Kmember and engine mounts.
If texting is easier thats fine with me 703 577 4730.
Car info:
87 Z28
2002 Ls1
Spohn Problem!
Ok so i have a Spohn K Member and i had two problems, the first was not being able run A/C in factory location got that fixed,but the k member and engine dont sit level with each other. Any ideas on how to correct the problem? I added spacers in between the block and the passenger side*engine*mount*thats seemed to help a little but it spaced the kmember out more than it pushed it up. Any ideas would be much appreciated.
Car info:
87 Z28
2002 Ls1
Car info:
87 Z28
2002 Ls1
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Spohn Problem
Car info:
87 Z28
2002 Ls1
Car info:
87 Z28
2002 Ls1
Car: 89 IrocZ
Engine: L98-ish
Re: Spohn Problem
Not sure if the answer in in this thread, but someone may have seen your issue.
https://www.thirdgen.org/forums/afte...ber-power.html
Re: Spohn Problem!
This wont be helpful in fixing your problem; but spohn K-members are known for having these issues. They make some great products (lca's & sfc's) but their K-members have had lots of issues.
I'm not sure if anyone has ever tried to fix the slanted motor issue. Most usually just switch to a UMI k-member; some just live with the slanted motor.
Sorry for not being helpful, I just wanted to give you a heads up that your not the only one having issues.
Car: 86 IROC
Engine: 5.0 TPI
Re: Spohn Problem
too bad that spohn didn't see fit to be the ones to "make it work" another example of them not giving a fu$# about their customers. and man I emphathize, it sucks that you got had by them. if it were me I would take it off and ship it back to them with a nice note describing just where they could shove it.
Car: 89 IrocZ
Engine: L98-ish
Re: Spohn Problem
I'd agree Rusty, but only after a few calls, or the "it's your problem" reply..
Real odd, Stephen made his name here on TGO starting with SFC's as I recall.
Too big for his britches maybe?
Car: 86 IROC
Engine: 5.0 TPI
Re: Spohn Problem
just one more buisness with a "WGAF" attitude. too bad .but in the end, aint karma a bitch?
Re: Spohn Problem!
Best fix for the engine slant is to fab a new pass side mount
What kept you from using the low mount AC, the brace?
Did your alt clear the drivers side brace?
Do your tierods rub at full droop/high bump?
Is the main hoop significantly lower than the Fbody oil pan?
Wheels centered in the fender openings?
ambainb
Apr 25, 2016 09:21 PM
