Cheap way to use LT1 stock fuel lines?
Car: 91 Z28
Engine: 350ci "fastburn 385"
Transmission: T56 / Quartermaster clutch
Axle/Gears: 9", 4.11, Auburn Posi
I just ran into a couple fittings on the OReilly website that look promising.
Adapters to go from 3/8 nylon line to 16mm O ring and 5/16 to 14 mm O ring.
Thus, you could presumably use these to go from the factory LT1 nylon lines straight over to the O ring hard lines on the chassis with just these adapters.
I hadn't seen anyone posting about these before. Together they are about 18 bucks. I have a long section of line I cut from the donor car, so I'm gonna give these a try I think.
Part number is 800-078 and 800-079.
Anyone tried this? Did it work? Seems like it should. Will give as much factory look as possible, but more than that it's dirt cheap and should be safe.
Car: 91 Z28
Re: Cheap way to use LT1 stock fuel lines?
I have an update to offer regarding these fittings.
In short, they do work, and look pretty good as far as a factory look goes.
HOWEVER- they do not work unless you modify them. SO - be aware that you are fooling with fuel fittings, and modifying them is not likely recommended.
Of course, I don't listen. . . .
The mods are as follows:
You need to drill the area where the O ring seats to match the size of the rubber lines that you are removing. My car had two high pressure rubber lines - so match the drill bit to the o ring seating area in there.
Using those drills sizes you just identified, drill the new fittings the same depth as they are made. You are just drilling about 3/16" deep or so - don't make the hole deeper, you are just making the diameter larger so the O rings will go in and seal.
Once that's done, I went ahead and drilled the ID out for a little better fuel flow. I think I went up 1/32 or so. These fittings just looked like they would be a flow restriction.
So with that said, they do work OK, just not ideal unless you have a drill press and a little time to devote to it.
It's a cost effective way to go, but I believe there are "better" ways to go if you don't mind spending a little more cash.
