Northern California Discussion board for Northern and Central California.
Cam Suggestions
Old 12-08-2016, 12:09 AM
eduardosac's Avatar
Car: 1990 Iroc-z
Engine: LS3/LSA blower
Cam Suggestions
I have a 1990 5.7L, automatic with ported edelbrock intake, ported slp runners, edelbrock headers, 24lb injectors, 58mm throttle body, with gmpp fast burn heads, I am looking for the biggest cam I can put in it and still pass the CA SNIFFER TEST, im willing to swap out torque converter and tune just to pass sniffer test...thanks in advance
Old 12-15-2016, 01:27 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Cam Suggestions
I passed with to comp xfi 268
Old 12-15-2016, 01:28 AM
antoine's Avatar
Re: Cam Suggestions
I passed with a comp cams xfi 268 cam
Old 12-15-2016, 08:25 AM
eduardosac's Avatar
Car: 1990 Iroc-z
Re: Cam Suggestions
Thats the cam I am leaning towards but im not sure on how to increase maximum valve lift on the fast burn heads to accommodate for the xfi268
Old 12-15-2016, 12:14 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cam Suggestions
Isn't the lift only .357/.354 ?
Old 12-15-2016, 12:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Cam Suggestions
Lobe lift. With a 1.5 rocker its .535/.531
Old 12-15-2016, 03:19 PM
Engine: Lb9
Transmission: M20
Re: Cam Suggestions
Ah ha, lt4 springs should work but I'm sure the guides need to be cut down.
Or 26918
Old 12-15-2016, 03:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Cam Suggestions
I would typically run abit more spring with that cam depending on the intake manifold. With tpi it wont go much over 4800-5000 so you can get away with bit less spring pressure. Hsr miniram i would stiffen up as cam will go to 6000 in a good headed 355. Lobes are pretty aggressive
Old 04-04-2017, 11:35 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Cam Suggestions
No problems here with an xfi268.
Old 04-13-2017, 01:23 AM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
Re: Cam Suggestions
Passed smog with xr276 hr comp cams and 1.6 roller rockers
Old 04-24-2017, 11:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Cam Suggestions
I agree with the XFI268HR-113 camshaft. Its like an LT4 hot cam but better ramps and lift, plus the 113 LSA makes it easier to tune and pass smog.
The Manley 22407-16 springs will handle .600" lift, too.
Old 07-07-2017, 10:21 AM
FAST LiFE's Avatar
Re: Cam Suggestions
Valencia1z, that's a fairly large cam with 224-int/230-ex duration at .050". You mind me asking what other mods you did and who did your tune?
Old 07-07-2017, 02:49 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Cam Suggestions
Whats a good head match for the XFI268? Ca legal of course
Old 07-11-2017, 11:43 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Re: Cam Suggestions
On mods during that time AFR heads as&m runners big mouth base 58 mm throttle body SLP shorty headers stock 5.7 24 lbs injectors 10 -12 base timing total I'm pretty sure around 32 to 34 total on a 350 low compression during smog set at 6 or 8 air fuel was always good and ran a vigilante 3200 gears 3.23 car was good for mid 12.s on motor on a mickey Thompson drag radials mid 11s spraying
