[For Sale] LSx harness $400 shipped
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
This is the harness from my last SC build, probably the last used harness Ill sell. If you're interested but its not exactly what you're looking for, shoot me a PM and Ill modify it to suit
$400 shipped
Specs:
Car, make, model, year:
90-92 Firebird/camaro
Original engine type:
TBI - V6/TPI also work
Original trans type:
Auto
Year of PCM being used:
99-02
PCM location:
Stock 3rd gen
PCM routing
Hidden under HVAC box (requires 2" hole cut)
Trans type:
T56
Intake:
LS3
Throttle Body:
Drive by cable
Injector style:
LS2/3/7 EV6
MAF type:
Truck 5 wire with external IAT. Can be put back for a standard install
AC:
4th gen low mount
Coolant gauge:
98 3 wire CTS
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Number of fans:
Dual
Battery location:
Pass side
Relay center location:
Hidden under battery tray
Extras:
Firebird tach booster, will disconnect for camaros
Speedo pinned for TBI, but its one wire to move for TPI/V6
IAT is separate from the MAF, can be rejoined for a stock install
LS3 front MAP location, LS1 connector. Can easily be moved to the rear for a LS1/2 intake
Coil connector are moved to the rear of the intake and use custom harnesses - included
Fans have an override switch for track days. Off- automatic PCM control, ON- fans run continuous with IGN on
Cruise control wires are pulled behind the intake at an inline connector, wasnt finalized
LT1/S10 style HO2s
$400 shipped
Specs:
Auto
99-02
PCM location:
Stock 3rd gen
PCM routing
Trans type:
T56
Intake:
LS3
Throttle Body:
Drive by cable
Injector style:
LS2/3/7 EV6
MAF type:
AC:
4th gen low mount
Coolant gauge:
98 3 wire CTS
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Number of fans:
Dual
Battery location:
Pass side
Extras:
LT1/S10 style HO2s
Re: LSx harness $400 shipped
I think this the exact wire harness that I will need. I have a 1990 tbi auto and I am going to swap an lq4 or lq9, t56, run l92 heads or ls3, ls3 intake, fuel rail, injectors and a ls1 tbi. And an ls1 ecm. Is this a common harness that you to do?
Car: 92 Firebird
None, all of my harnesses are built from scratch. This was the last used one
It would have a been almost perfect. However today I came across a 02 LS1 T56 engine harness with the ECM for $200. Is this a good deal and if it is would it and my existing harness be all that you would need from me to start making a harness?
Car: 92 Firebird
It is a good deal if you're doing the wiring your self. I dont modify used harnesses anymore. Everything out of my shop is new
I have an '86 IROCZ that I am building an LS1 for with a 700R4 that I am going to need a wiring harness and pcm for, everyone tells me you are the man to see so here I am. Can you help me?
BlackphantomZ28
04-24-2016 08:14 AM
Sanjay
08-12-2015 03:41 PM
