Shock and Awe
Shock and Awe
I recently bought myself a Moser 12 bolt and was taking out the GM 7.75" 9 bolt that I had gotten from an 88 GTA Trans Am a year or so back so that we could install the new rearend when we noticed what's in this picture. The shock had ripped a piece out of the body inside the car and out of the frame work inside the hub. Has anyone else ever encountered this.
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Shock and Awe
Yeah, that ain't normal. When I swapped my shocks, the hole was only like 0.5" across... not 1.5" across. lol
I have never seen that happen before. Would you just weld in a new piece of metal and redrill the hole? It makes me wonder if I should try and do something to strengthen that area.
Mike
Mike
1 Post
Car: projects.......
Re: Shock and Awe
Not overly comon on a car that does not appear to have a lot of rot/rust, but otherwise, fairly comon for these cars and their age. It's only very thin sheetmetal and with the load the shock has placed on it these past 17+ years it tore.
Weld a piece back in that covers a good distance out and around the hole. Drill a new hole for the shock to mount and go on with it. - This is why it is so important to brace everything if you switch to coil-overs.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
Re: Shock and Awe
But if the hole isn't in the exact same spot, won't it alter the suspension characteristics?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Shock and Awe
No. Shocks aren't all that picky about the placement. Within a 1/4" and you'll be fine.
sofakingdom mentioned this as being pretty common back in the day (in his old posts)...
Re: Shock and Awe
I've had that happen on two of my 3rd gens. And seen it on a few that I've scrapped out. To prevent that from happening on my 88, I welded a thick washer over the hole for each shock.
Re: Shock and Awe
This was done by a regular shock. It ripped a piece out on the underside in front of the coil spring too. I'm probably going to cut a piece out of anther 3rd gen f body and weld on top of it on both sides and weld a piece of thicker sheet metal on the inside.
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
