GM Braces That Amuse and Confuse
The first is BRACE, Fdr to Upr Cowl, a piece found on the pass side and which has no sister piece on the driver's side (pic #1). Purpose? Amuse and Confuse.
The second is BRACE, Whl Hse Pnl reinf, a piece found on the pass side and which has no sister piece on the driver's side (pic #2). Purpose?
The third is BRACE, F/End Upr Structure, a stamped piece found on the driver's side, which appears to support the vapor canister tray, and which has no sister piece on the pass side. A bolt passes through the tray and ties into the fourth brace (pic #3).
JamesC
JamesC
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: GM Braces That Amuse and Confuse
I've often wondered about these myself. But I've never seen it written anywhere that GM engineers were rocket scientists either, so I gave up trying to second guess their 'wisdom'.
1 Post
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I just removed all of mine and welded up all the holes. I have SFC's, a tubular K-member, and a wonderbar for stiffness. We'll see what happens. I don't think they do much as they are small diameter and are installed with small bolts.
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
so we should get rid of this junk and save the 10lbs?
Car: Turbo Buick
Engine: 3.8 V6
Getting rid of this stuff is not a good idea if you really do value rigidity. The stuff GM put on these cars is more effective than half the aftermarket crap they sell for these cars. It's not hard to understand why most of these braces are there if you think about the forces being imparted to those areas. Consider that the car is not symmetrical from one side to the other and hence not equally stiff from one side to the other.
Part of the misunderstanding seems to come from the idea that a brace needs to be stiff in all directions to be effective. The truth is that these rods are quite effective when the loading is axial, especially in tension. Think suspension bridge. Although in the case of these particular braces pictured, they most likely see compression more than tension.
BTW the brace on the driver's side frame rail? That's to help prevent the steering box from flexing that area.
Engine: 4++,350 & 305 CIs
I parted a 92 GTA that had 2 of those little braces from top-mid strut tower to frame rail. 1 on each side Dr and Pass
The last one you posted is to help support the battery weight.. on firebirds. and it strenthens the frame for the steering box.
And I hear it (along with the 2 triangle K-member braces) did help the steering box frame rail strength on cars with 16" wheels
The other 2 have me at a loss, the one over the AC box from hood hinge base to firewall side who knows? All of my cars have it.
yeah im gonna check and see if mine has any of those... then ill scrap 'em!
From Spohn: Not all Thirdgen F-Body Camaro and Firebird cars were factory equipped with triangular braces on each side of the front of the k-member to reinforce the front subframe at the steering box mount. These braces reduce flex and cracking of the front subframe and are a recommended addition for any street driven car.
I've 'read' that some Camaros weren't equipped, that some were equipped with one, some with two.
JamesC
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
My 84 Berli did not have these triangular braces for the K-Member. John has also confirmed that the early Berlis did not come so equipped. The holes were drilled and tapped and they were a simple bolt-on after a trip to the yard.
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
I believe earlier camaros don't have the triangular braces and later ones do. I feel like the cutoff is 86-87 (86 cars do not have the braces and 87's do) but I'm not positive that's true. I know my 92 RS had them but I had to take them off to fit the LS2 alternator and A/C compressor. And I do not have that cowl brace for sure. Very strange!
1 Post
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
My 82 also had the two k member braces, and just about every other one posted.
Car: Turbo Buick
Engine: 3.8 V6
Jacking and supporting the car in different areas I can definitely tell that the brace is doing some work as evinced by the creaking coming from the fastened ends.
BTW in the above book you can see pictures of various other braces that GM experimented with but never put into production. Fabricating these might be of some value. I'm guessing they all worked to some degree, just some were more cost effective than others. One that piqued my interest was a set of braces from the center of the bottom of the k member going forward, presumably to the rad support area? I am only assuming that is where the other end attached because iirc the picture only shows one end. These were intriguing to me because some G bodies received a very similar set of braces. So there must be some rationale behind them. I haven't looked at things enough to have drawn any conclusions yet.
Much like the wonderbar only being installed on IROCs. The stickier tires and firmer suspension could be expected to place more stress on the chassis vs. my 84 berli with no rear sway bar and 14" wheels.
The passenger side strut tower braces were a Z28 only thing, at least up to 87. I've not seen these braces on any Pontiacs though (except the ones I installed on my 85 TA).
For what it's worth:
Brace, Whl Hse Pnl reinf-RH (Z28), is listed 82-91 in my Parts and Illustration CD. Though the Z28 business is only listed 82-86, the part number is the same for all years, 14045394.
JamesC
And my 84 Berli conveniently came with a welded frame rail where it had been cracked in the past about a half a foot behind the steering box.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
They don't exist on mine either. Though my engine had been swapped by the time it came into my hands, a lot of little stuff like this was missing. Great thread for an unusual subject - I wasn't even aware of these braces. Will look at mine tomorrow to see is the mount holes are there. Maybe they were to silence various little creaks and rattles, I have enough of those!
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I don't believe so, but I will take a look out of curiousity. However, mine is a RHD mirror conversion, so if there was no sister brace on the other side, that would be a no.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Ok, checked it out today. Fwiw I've got none of the braces mentioned in the thread, and had a badly cracked chassis rail on the Aussie (your passenger) side - take from this what you will. A shop weld job and a homemade wonderbar later, permanent fix.
1 Post
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Those braces do seem week and flimsy but the whole car is. On the brace that goes from cowl to fender I can see scratches on the top of the wheel well from the tip of the bolt that holds the brace on. there is about a centimeter gap between the tip of the bolt and the surface it scratched. To me that shows the car flexes like crazy and these wimpy braces actually do try to hold it together.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
did you ever find out if these are worth it? i have a chance to buy the one that goes from the hood hinge to the cowl and another that goes from the passenger strut tower to the frame rail. are they worth it?
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
My 92 RS did NOT have either of those passenger side braces. It also had the crappy cruising suspension. Could be some merit to that line of thought. But that fender-cowl brace goes through the hole my map sensor was in - did they run the brace AND the MAP sensor through that same hole?
It does have the K-member braces, though.
This is from Camaro: The Third Generation, but it only talks about the development of the 82 model, and it's the Dec 81 edition, so you'll have to extrapolate on your own how it applies to later models:
#44
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
There is a hypothisis in the community that the "wonder bar" was infact called a "wander bar", reason being attached to the steering box and helping to prevent "wandering" in the steering due to the 2 subframes able to twist the body. It is suggested that the term was/has simply been mispelled to "wonder" through mistranslation.
I can see this as being quite a reasonable suggestion, though no hard proof of evidence has come forth
#45
JamesC
#46
Engine: L31 350
So those two braces aren't even worth $6? Do they help support anything at all?
#47
The cowl brace attaches to the same point that the Baro sensor is installed on carbed cars. The other end actually attaches to the hood hinge. I've put one on both my 87 and 85 TA (I've only seen them on Z28s never on Pontiacs).
Oh, my Berli did not have the inner fender brace, either side. I'll be installing them as I rebuild it, though. Random progress pic:
#50
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
All 86-92 cars were factory equipped with a triangular brace on each side of the front of the k-member to reinforce the front subframe at the steering box mount. These braces reduce flex and cracking of the front subframe. They were options on 82-85 cars.
