tubular front suspension for 3rd gen
Old 04-21-2013, 05:23 PM
Larry Woodfin's Avatar
Sometimes I consider changing from the factory front suspension and K member to lighter weight components.
My 1990 Firebird has an S-10 manual box, light weight custom column and Santhuff double adjustable struts. All other front suspension and steering is factory.
In addition, it has Lemons 1 3/4 x 1 7/8 headers so that fit is important.
The car weighs 3020 with driver and runs 6.10's 1/8 mile with aluminum head SBC.
My expectations are:
* remove about 80 pounds net from the front-most section of the car
* improve engine and header access
* car would have less steering effort at low speed
* front suspension would retain full suspension travel
For those of you who performed this conversion did it accomplish what you expected?
Old 04-21-2013, 05:30 PM
Re: tubular front suspension for 3rd gen
I did not make myself clear, I would change to rack & pinion steering as part of the upgrade. In addition, would consider changing to lighter weight brakes.
Old 04-21-2013, 08:35 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Larry, I did this conversion to reduce weight off the front end because I am putting in a BBC, this would off set the increased weight of the new engine. I did tubular A-arms and K-Member as well as rack and pinion. Move battery to back of car.
Old 04-21-2013, 11:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although the front k-member looks big and bulky, switching to tubular doesn't shave off as much weight as you would expect. It does however give a lot more clearance around the engine. You're not going to remove 80 pounds by switching to tubular.
Old 04-22-2013, 06:38 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
The difference might be about 20 lbs. Hood, doors and hatch are the heavy culprits on these rides...
Frozer!!!
01-19-2024 04:55 PM
customblackbird
08-15-2021 10:16 PM
Terrell351
06-13-2021 01:13 PM
1992rs/ss
05-19-2020 07:02 PM
sweet_87_iroc
09-25-2015 10:01 PM
Quick Reply: tubular front suspension for 3rd gen
