Lee 670 Series 12:1 Steering Box
I finally pulled the trigger and purchased one of these. There isn't a whole lot of info online regarding these boxes, and most of it being anecdotal, or directly for the manufacturers themselves (Flaming River, AGR, etc.)
So I installed yesterday, and the results are in; the hype is real.
I've only driven it around for a day, but this is IMO the closest you will ever get to a rack and pinion feel with a steering box. The road feel is excellent, and there is no famous "dead spot". It fit perfectly in the car, too. (Note: I had them grind off the forth mounting boss, as that is used for trucks only and would interfere with a spot on the frame).
I highly recommend this gear.
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Lee 670 Series 12:1 Steering Box
Great. Big help if you follow up in 6 months.
Lee fan, myself. Some others, not so much.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Looks cool! Interesting they used safety wire on the cap bolts. At least we know they are ****! Definitely give us a report down the road.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Sounds cool. Did the exterior dimensions change at all or is it a factory box with upgraded guts?
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
