Factory LCA Bracing?
I noticed these braces inside the LCA's on a car in the boneyard today. The car was nothing special, an '85 LG4 Auto. I've never seen anything like them before, though I must admit that I have never looked for them. I'm guessing they were extra bracing for the LCA's, but are they factory or aftermarket? They fit perfectly in the side holes of the factory LCA's; either the front two or the back two. The car I pulled them from had them in the front two holes, towards the front of the car. Just curious what I stumbled onto.
Car: check
Engine: check
Transmission: check
Re: Factory LCA Bracing?
Yep, some 3rd gens got them while many others didn't. I don't know which ones or why, other then it will make the arm less flexible. Those braces were also used on g-body's that had a rear sway bar. The bar ends bolted to the LCA's with the brace preventing the arm from collapsing.
RBob.
RBob.
Received 1,672 Likes
Lots of parts on these cars are like that; semi-universal, so they fit a bunch of different body styles. Just like the front LCAs, which have shock holes, even though these cars don't have front shocks at all.
Car: 82 Z28
Transmission: TH350 for now
As noted above it was for the G-Body sway bar that mounted between the two LCAs, they prevent the LCAs from collapsing when the sway bar bolts are tightened down through the LCA. My guess is either someone swapped in the LCAs from a G-body or just the two little brackets thinking they will add strength.
Could have been from the factory but I would be very surprised.
Yeah, I'm pretty sure this was original to the car. The body nor the suspension were in particularly good shape, though it's hard to say what has happened to the car over the last 30 years. I was measuring the rear sway bar when I noticed it. 18mm rear and 32 solid front.
Yup; seems kinda random which cars got those LCAs and which got the ones without. There's quite a number of mysteries like that about these cars; almost like there were several suppliers or plants, each of which was given a different set of drawings, and none of which were operating at the same time as the others. Typical "old GM" in a way, I guess.
Engine: 4++,350 & 305 CIs
I haven't seen them on any 86 and up cars, anyone else?
Car: 1996 Firebird
Engine: 3800 Series II
Transmission: 4-speed Manual w/ OD
Picked a pair today a U-Pick-It off a 85 Z28.
Also saw two cadillac's with the sway bar attachment bracket - they are not the same - and are mounted at the rear of the LCA on the caddy - but at the front on the Z28 LCA.
Car: 1996 Firebird
FYI
Per GM parts diagram - Lower Control Reinforcement p/n 10000097 used on 83-86 Camaro.
Car: 1996 Firebird
