UMI Roto-joints Rear LCA
Now, poly-poly LCAs are in my rear, but I'm planning to change them to UMI's roto-roto LCAs.
My car is complete for street use, and I don't like harsh ride.
How good roto-joints are for street use?
Are they harsher than poly-poly LCAs?
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: UMI Roto-joints Rear LCA
When I went from rubber to Spohn Del-sphere (both sides), I didn't notice ANY increase in ride stiffness. The car did feel tighter. But not any stiffer riding at all.
Del-Sphere and Roto-Joint are basically the same thing.
Thanks.
How are the noise and vibration?
No difference?
UMI also prepares poly-roto LCAs, so I suspect there must be some downside of roto-roto LCAs...
No difference?
Car: 1989 GTA
None. Absolutely zero...... My city is all concrete roads with way too many potholes, cracks, and bumps. And I live near the center of the city. So it's not like I live way out of town on rarely traveled roads.
I owned the LCA and PHB for quite some time before putting them in. Precisely because I was worried it would ride too hard afterwords. But I gave up nothing for the increase in performance.
I'm not sure that poly would even ride any smoother. Poly doesn't have any movement. Roto-joints can rotate when they need to.
Thanks for your info.
Now I've decided to go for roto-roto.
I think roto-roto ones are ideal because both sides of LCAs should have free movement to prevent bind completely.
Btw, how about the maintenance cycle of roto joints?
Did you retighten them? If so, how long until retightening?
However, they come with greasable fittings, so you should grease them once in a while.
The Delrin part does wear out, but then you just need the wrench and you can tighten them again.
Hey guys.
Our intention with poly-roto vs roto-roto is to have the poly be potentially a little "softer" but if dual roto doesn't pose any problems in real world conditions that's a pretty nice testimonial.
We've seen street cars go a few seasons with no roto adjustment required where others (maybe with lots of abuse) need a quarter turn every so often. The Roto-Joint really is a cool piece and works well.
Maintenance is usually a few pumps of grease a few times per season.
If they do wear out, the Delrin pieces are $6 per end ($3 each side of the ball). As an example I get about one call per month, maybe less, with guys buying them.
Let me know if you have any questions.
thanks
ramey
thanks
ramey
Hey guys.
thanks
ramey
thanks
ramey
Thanks for the reply Ramey.
Just one question: How can you tell if adjustment of roto joints is needed?
Cluttering noise or something?
Or take them apart anyway and see if there is any play?
If adjustment is required, you will see some play during servicing. Or if you lift with a floor jack you can see movement. Some Roto-Joint arms last many many years before needing tightened.
ambainb
04-25-2016 09:21 PM
LT1Formula
11-16-2015 01:13 PM
NBrehm
08-05-2015 07:57 PM
