front struts??????
front struts??????
what are your thoughts or what have you used for front struts i was thinking lakewood 90/10 or a set of 70/30 and also was looking at kyb adjustable front struts I have a 91rs swapped the v6 for a 383 stroker also trying to get an ideal on spring also if anyone has some info it would be greatly appreciated!!!!!!!!
Re: front struts??????
An important factor is what conditions you will be using them in-- auto x, drag, daily, etc; and your budget!
You can find all kinds of threads on practically any type of strut/shock/spring on this site. I used it when i picked out my KYB Excel G strut/ Gas Adjust shock combo this spring and was really pleased with the results for cruising. Whole setup cost me $100.
Here's a tip if you're getting too many results when you do a general search using the red search box: you can put words in quote marks for better matches, like "Lakewood strut" to find results like these: https://www.thirdgen.org/forums/orga...od-90-10s.html
Also note: there is a flyout menu in the blue bar to "Search this Forum" to limit your results to a certain forum once you're in it i.e. Suspension and Chassis
Good luck!
Good luck!
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
get some 90/10s and go autocrossing... make sure someone records it and that you post it here because that would be awesome...
That would be funny to watch but I think I'll pass on that one I know what I'm doing just was wondering if anybody has used the kyb adjustable struts and if they liked it or not my go to is Lakewood 90/10 on my drag car but was wondering if anyone has used the 70/30 on the street and strip and there feed back not smart *** remarks tnx
I love my struts I got from TPIS. 150 bucks. They are custom valved, and adjust to how you drive. (stiffen up with more aggressive driving) I know a couple guys that work there and have talked to them in person about them. IMHO, thats what id get. I know everyone here loves the yellow kohns or what ever. Im sure there is better out there but for 150 bucks, hell of a deal.
Antone else out there run TPIS struts?
-Dan
(edit) And come with a LIFETIME warranty.
-Dan
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I run Koni SPA1 front struts on my drag car. When set full soft, the front end is very bouncy and I can grab a fender and easily lift the car up and down. To help keep my front end on the ground, I have them cranked up as stiff as they can go and use a travel limiter. Can't even move the front end when at full stiff.
Adjustable shocks are a tuning aid. There is no real "one setting fits all situations". If you want to throw in a set of shocks and forget about them, put in some aftermarket OEM type replacements.
I run the KYB adjustables AGX up front in my car. They work just fine. Mainly bc i can't afford koni yellows lol and I don't drive The car hard like autox etc. Mines a pleasure car so it's only seen like 500 miles in the last couple of years. I ran them with a 900lb front spring and a 200lb rear with gas a just kyb rear socks. Now I have 850 lb front weight jacks with the AGX struts, and 150lb rear weight jacks with viking double adjustable rear shocks.
My rear gas a just are for sale btw.
Car: 86 Camaro
-Dan
-Dan
got one of them there linky thingies?
https://www.tpis.com/ when the page loads, top right in red "download catalog" Page 18.
I have one of their old catalogs and the description says, filled with nitrogen gas and controlled by full displacement valving. Piston rod is chromed and sealed with an o-ring and not a nylon band. They say they used the same technology in improving the Vet strut and took that to the 3rd gen strut.
-Dan
-Dan
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
TPIS hasn't sold these struts for 5 years now. I called today to ask and spoke with Bob. He thought it was weird that they were getting a bunch of calls lately.
He also had a great comment about how all the good options today don't make it ride well...something about how people think you should be internally bleeding after trip around the block to show how well it performs.
I have a stockish G8 GXP and really like the firm, yet liveable handling... I must be getting old...
