Wanting to lower my 84 coupe
I would like to lower my 84 coupe. Has anyone tried these springs?
http://www.summitracing.com/parts/ei...t/model/camaro
And....do you have to alter anything else when using lower springs? Just getting ready to put it in the garage for winter and get stuff done.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Wanting to lower my 84 coupe
keep in mind that your stock springs might be sagged to the point that you might wind up at the same ride height (or higher) with those springs as the ones that you replace..
Also it was a factory V6. Now there is a V8 in it. I am wondering if they left the V6 springs in it. They look older. I dont know how to tell. But I would imagine the V8 is heavier.
I didnt think of that. The last person put some type of spacers on the front springs to make them stiffer I guess. He said it was leaning on bends and bottoming out.
Depending on how far you go, you may want a adjustable pan hard rod. I don't have one and I've lowered my car probably about 3" in the rear and probably 3/5 - 4" in the front. But I'd for sure get some lower control arm relocation brackets.
ambainb
10-10-2015 08:19 PM
