Lower door hinge Q? (Not pin)
Old Oct 8, 2015 | 01:09 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
This is very loose on the lower hinge "detent arm" ...
Can it be welded ? / where ? ... It was "expanded" on the bottom originally, but I think I can weld at the top and have it still rotate in the center portion ?
Any help appreciated !
~DaVe
Old Oct 8, 2015 | 02:26 PM
86IROC112's Avatar
Car: 1986 IROC Z
Re: Lower door hinge Q? (Not pin)
Dorman sells a pin and bushing kit for less than $10. It's a bitch to install but can't be any worse than what you are talking about. Those upper pins on the lower hinge have to be cut or ground out. PITA but if you are going in there might as well replace 'em all.
Old Oct 8, 2015 | 05:11 PM
BumpaD82's Avatar
I don't think this is suppose to be one of the replaceable parts in the Dorman kit ... I have two right here ... It outboard of the lower hinge pin on the roller arm ?!
Old Oct 8, 2015 | 07:03 PM
86IROC112's Avatar
Car: 1986 IROC Z
My bad. I guess I saw "door hinge" and started having nightmarish flashbacks of doing my pins and bushings...
Old Oct 8, 2015 | 11:04 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Call and talk to Lon at "Top Down Solutions" about your problem.
Here are some of the kits and parts they sell and I installed the non-greasable upper and lower hinge kit 9 years ago and it is still going strong.
His pieces are made out of quality materials and worth ever dime.
Link to there site = http://www.top-downsolutions.com/Bod...y-and-Interior
Lon at
Phone # (626) 369-0040
1977cutcher
Nov 1, 2015 08:51 AM
TheBadazz
Exterior Parts Wanted
Oct 2, 2015 10:53 PM
sleprock
Members Camaros
Oct 2, 2015 11:24 AM
