sway bar endlink length
Car: 1986 T/A
hey guys, i just purchased sway bar endlinks for my car both front and back. i bought them at hawks because i was getting a few other parts from them. the endlinks are made by energy suspension. when i got the parts in, there were two sizes. 2 of the endlinks are linger then the other two. Im not sure which go on front and which go on back. any help would be appreciated
Car: 1986 T/A
Re: sway bar endlink length
yea thats what i thought. but one sleeve is the same as stock and the other is longer but not by a whole lot. might just cut the sleeve to make them the same size. will it really matter if they are different sizes? another question, i have the 36mm front swaybar and the new bushing mounts dont have offset holes so the bushing sits slightly crooked to the swaybar. is that going to be a problem
Received 1,672 Likes
It works best of bar is level.
The exact length isn't all that critical. Correct for these cars, if memory serves, is around 2¼ - 2½". But as long as the bar is about centered in its travel, it's fine.
Car: 1986 T/A
I think i got the fronts on. i used the longer ones in the front because it seemed to get the eyes on the swaybar to sit level. ill take a picture tomorrow. i have the shorter ones that im gonna try to use for the rear. they are the same size as the ones on the rear now but they dont looks correct.
There are usually a few different lengths available for each platform of vehicle for variances that occur because of the geometry of the car.
We used to include long end links in our A-Body front sway kits that most customers would trim down to fit, after much complaining we shortened the end links up that came in the kit. With the shorter links we will every now and then have a customer that will need a longer end link in order to make the sway bar clear components because of a fitment issue pertaining to the cars particular geometry.
As stated above the correct length isn't all that critical as long as the sway bar fits with no clearance issues.
Craig
Craig
9manastacio
87
11-22-2016 08:26 PM
[For Sale] part out 2006 ls2 gto magnacharged t56 OHIO
marokid
LSX and LTX Parts
09-09-2016 05:26 AM
