L98 heads on an L03?
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Hey I know someone that has some L98 heads that they are giving away.. there completely bare tho. So my question is, will there be a worthy power gain from the swap or is it not worth the trouble? And about how much would it run for valves, springs etc? or will the ones on my heads now work with these?
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Not worth it, your compression ratio will go down a lot and will negate any gains from the extra flow.
1 Post
Car: 92 Z28
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is a drop in compression but the heads are still superior to that of the stockers. I would still use them and live with the CR drop. Not ideal but better. You could get them shaved and use a thinner head gasket as well if you have the funds. Your efforts will be pointless though unless you go with a better cam.
