O-ring Size
Old 07-28-2011, 08:43 PM
89RSRedConv's Avatar
O-ring Size
Does anyone know the size of the O-ring that is on the hard fuel line going into the TBI? I tried a 5mm and it still seems to leak.
I think I saw a kit a Hawks , but I have some just wanted to try them before i bought something.
Old 07-28-2011, 11:06 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: O-ring Size
O'reillys...or well Kragen's used to sell a universal GM o ring kit (it has a bunch of brown o-rings in them) that had the right size in it. Other than that go to the GM dealer and get it. It's a lot easier than the trial and error. and be prepared to deal with getting that thing to stop leaking for awhile.
Old 07-29-2011, 06:40 AM
Re: O-ring Size
Wow, the entire country has O Reilly's Auto parts then they hit PA and stopped dead, no luck in NY.
They Have BWD - Fuel Injector Seal/O-Ring Kit Part # 27478
Hawks has this part O-Ring Kit, 85-92 TPI Fuel Line O-Ring Kit, GM Item Number: 6256/4722
I assume that is what I am looking for, I will try to look around locally see if anyone has it for the weekend than just order one on line, Hawks seems like a better deal .... its just I have a universal o-ring kit if I knew the size .....
Old 07-29-2011, 10:44 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: O-ring Size
that borg warner # may be correct. I dont know if the TPI o rings are the same. Id say maybe...your local GM dealer will have them for a couple bucks
Old 07-29-2011, 12:32 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: O-ring Size
Check with these guys
http://tbiparts.com/
Old 08-01-2011, 10:42 AM
Re: O-ring Size
That's a good link, I tried the O-ring without any luck. I am now wondering if the fuel line is damaged where it is flared and does not make the correct connection, it is not a slow or minor leak lots of gas dripping out.
I am on the hunt for another line. will post once I get further.
Old 08-08-2011, 06:57 AM
Re: O-ring Size
Fuel leak fixed just slapped an O-ring on and tightened the bejesus out of it, hoping it holds because it's never coming off. May still look for the line but now I have a part number and a place to find it.
Thanks guys for all the help.
Pac J
05-17-2020 10:44 AM
BrianChevy
Wheels and Tires
10-13-2015 12:33 PM
PAFORM350
Wheels and Tires
10-02-2015 07:21 PM
dbrochard
Interior Parts Wanted
09-28-2015 07:40 PM
Twinn Engines
South East Region
09-25-2015 06:25 AM
Quick Reply: O-ring Size
