18psi spring too much?
Old 02-06-2016, 03:23 PM
dwrestle's Avatar
I put a higher pressure caprice cop car fuel pump in my truck, and am wondering if 18psi spring would be overkill, and crappy running? I have a cfm tech tb spacer, and injector spacer. I also have the salad bowl(not rigged up just dropped down in there), I replaced the intake pipes with higher flowing stuff, and exhaust. I will have a chip whenever the guy finally sends the freaking thing. I already bought the 18psi spring, but I'm thinking I may be better off with a 14psi spring.
Old 02-06-2016, 04:23 PM
Schurkey's Avatar
Re: 18psi spring too much?
Does the engine run lean at WFO/max RPM with the 14 psi spring? If not, the 18 psi spring is unlikely to do anything useful.
Old 02-06-2016, 08:31 PM
dwrestle's Avatar
It's got the stock spring in it, and it does seem to run lean.
rusty vango
07-05-2016 03:09 PM
HasseO
02-04-2016 02:49 PM
'91CamaroRS
01-23-2016 01:28 PM
RamIt
Carburetors
01-21-2016 07:20 PM
IROC406
01-19-2016 01:35 PM
Quick Reply: 18psi spring too much?
