what did this engine come out of??
Old 11-10-2002, 07:11 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i have been trying to figure out what my engine came out of. on the back of the block on the passenger side it sais 14010201 GM 5.0 LG, then on the fron left of the head it sais V0301CDJ 2FN220/2/, i searched the net and it said an 85-90 oldsmobile 307 said GM 5.0 LG, so what do u guys think and where can i find out?? and what kind of oldmobile had a 307? thanks alot
Old 11-10-2002, 07:21 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
i have no idea technically speaking but oldsmobile never mad a truck in those years so it probably out of a delta 88 or whatever caprice equivalent there was for that yeat...just aguess....
Old 11-10-2002, 07:32 PM
ctandc's Avatar
The code that tells the tale is the suffix code, the letters and numbers off the front passenger side of the block, right behind the alternator.
You listed CDJ which decodes as a 305 LG4, from a F body, G Body or B body.
HTH
84z96L31vortec
08-20-2017 12:16 AM
Spyder_TheGamer
12-25-2015 05:07 PM
Reddeath210
10-06-2015 08:20 AM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: what did this engine come out of??
