Coil question
Old 07-21-2003, 09:23 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Coil question
When cranking the car over with the ignition system disabled, such as for a compression check....I've always disconnected the wire from the coil to the cap and put a thick rubber cap over the coil terminal. I've just thought about this now...at like 50,000 volts...could this be damaging the coil by causing some sort of feedback or something? Is it better to, say, leave the wire on the coil, but pull it off of the cap and ground it somewhere away from the engine? Thanks.
Old 07-21-2003, 10:27 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
What you're doing is fine. There is no path for the current to follow, so there is not voltage going through the coil.
If you were to ground it, you would get voltage running through the coil, as well as through the whole engine. Not really bad, but you'd have to be careful about letting a wrench ground out.
Old 07-21-2003, 10:30 PM
Nixon1's Avatar
Oh alright..I gotcha.. So the coil doesn't fire unless it's got a completed electrical circuit?
Old 07-21-2003, 10:38 PM
AJ_92RS's Avatar
Right.
Old 07-22-2003, 09:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It makes more sense to disconnect the primary (12V) side of the coil and leave the secondary (high voltage) side alone.... then there's absolutely no possibility of spark
Old 07-22-2003, 11:15 AM
AJ_92RS's Avatar
It makes the most sense to get in the habbit of disconnecting the negative battery post every time you're working with something electrical, or for any part of the car for that matter.
Old 07-22-2003, 12:00 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
but that sure makes it hard to crank the car over, eh
lt1z350
08-28-2015 05:57 AM
TheExaminer
08-25-2015 07:34 PM
Bryan F
08-18-2015 02:28 PM
transamgta1Khp
08-17-2015 12:18 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: Coil question
