Torque specs. Vortec heads& intake
Old 10-20-2000, 11:18 PM
NORT's Avatar
I'am installing some new Vortec heads on my 84 Z-28 it is a 350ci.motor. I have everything that I need to do the job except I need to know the torque specs. for the heads and intake. I don't know if they are the same as regular SBC torque specs. With the weird bolt set-up on the intake I thought they may be different. I would appreciate some info. NORT
Old 10-21-2000, 01:12 AM
CamaroZ_85's Avatar
if you cant get answers, then i'd go to a parts store that will let you look through a book. find one w/ vortec trucks and your answer will be there
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old 10-21-2000, 03:20 AM
BOWTIROC's Avatar
Location: Coulterville, IL...Currently on Beale AFB, CA
Stock chevy cast heads are around 65-70ft/lbs. The aluminum intakes are around 25ft/lbs
Old 10-22-2000, 12:04 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
vortec intake specs are 11ft lbs, they have a special gasket that you can *** up if you overtighten it, heads are standard I believe
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
92projectcamaro
01-18-2016 08:00 AM
86CamaroDan
09-29-2015 10:08 PM
angel2794
09-08-2015 06:22 PM
z28addict8490
09-05-2015 03:56 PM
Quick Reply: Torque specs. Vortec heads& intake
