adjustable vacuum advance
Old 11-29-2003, 08:33 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
I just bought a new mallory hei distributor and it says it has an adjustable vacuum advance, How do I adjust it?
Old 11-29-2003, 11:24 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
This should get you started
Old 11-30-2003, 01:19 AM
Engine: LG4 305
The reason I ask this is because my dad said the vacuum advance isn't working properly, he said if you suck on the advance it should hold vacuum, but it isn't, it justsucks right through and doesn't hold. does this mean we have to adjust it?....And could this be causing my car to bogg down at WOT?
Old 12-01-2003, 04:40 PM
Car: 87 Firebird
Your dad is right, the vacuum advance canister should "hold" vacuum. I would replace the vac adv can. At WOT there should be little to no vac adv, it will all be mechanical. Vacuum adv is for part throttle cruising, milage, and sometimes idle.
83 Crossfire TA
01-03-2016 01:26 PM
Jorlain
10-08-2015 01:57 AM
86CamaroDan
09-29-2015 10:08 PM
angel2794
09-08-2015 06:22 PM
Strick1
09-04-2015 07:11 AM
Quick Reply: adjustable vacuum advance
