View Poll Results: DOES CAM LUBE GUM UP ROLLER LIFTERS?
No, it does not.
50.00%
Yeah, don't use cam lube on roller lifters!
50.00%
Voters: 6. You may not vote on this poll
CAM LUBE on a roller cam... Good or bad?
Old 02-24-2004, 08:29 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
There have been mixed opinions of using cam lube with roller cams. They're fine for flat tappet cams, but what about rollers? Does cam lube gum up the rollers on the lifters, or is it perfectly safe?
Old 02-25-2004, 05:25 AM
ede
ede's Avatar
depends on the lube, all in all i prefer lubriplate 105
Old 02-25-2004, 05:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Unnecessary
Old 02-25-2004, 08:15 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you shouldnt use it on the rollers or lobes.
a small amount is fine on the bearing surfaces and distrib gear. just dont go crazy with it....
you'll have to do the "break in" warm up since you used it..... then drain the oil while its warm..
that will get most of it out.
Old 02-25-2004, 10:11 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I use straight 30 weight oil, non detergent for assembly. Regular multi-weight oils have detergents in them that attract dirt (that's the detergent's job) which isn't good for an engine sitting with it's guts exposed. I would use break in lube if I didn't plan on firing the engine for a while though since it's thicker and will stay in place until the engine fires. I would only use the assembly lube on things like bearings and bearing surfaces though, and not on a roller cam lobe surface. The roller lifter wheel has it's own internal bearings and the wheel of the roller doesn't need lube to be able to turn the camshaft without damage. On the lifter bore perhaps, but not the lobe surfaces...
84z96L31vortec
08-20-2017 12:16 AM
camaro71633
09-01-2015 10:24 AM
ZZ42Fast
08-10-2015 08:20 PM
BrianI
08-09-2015 11:52 AM
anesthes
08-08-2015 09:37 PM
Quick Reply: CAM LUBE on a roller cam... Good or bad?
