harmonic balancer center bolt stripped
Old 10-10-2004, 07:49 PM
omarr's Avatar
bolt came loose and wobbled. pulley came off. i took the balancer out but the crankshaft hole is stripped. the centerbolt wont go back in.
Old 10-10-2004, 07:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Heli-coil
Old 10-10-2004, 08:03 PM
omarr's Avatar
what is a heli coil
Old 10-10-2004, 08:56 PM
NascarFool's Avatar
Car: 1989 Iroc-Z
Heli-Coil
You could also try to use a tap and thread the hole to fit a different size bolt. Is it completely stripped or just the first part of the threads stripped ?
Old 10-10-2004, 09:49 PM
omarr's Avatar
just the first part
Old 10-10-2004, 10:07 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
how deep on the bolt is it stripped???
id get a new bolt for it and a tap and clean the threads out really good and see if it will work
Old 10-11-2004, 12:29 PM
a73camaro's Avatar
The stock hole in the crank is 7/16" x 20
The next size bolt is 1/2" x 20
First try to tap the existing hole with the 7/16" tap. Make sure that the bolt has clean threads.
If the threads are too buggered up, then tap with 1/2" x 20 and buy a larger bolt. Also any of the 7/16" threads will help guide the 1/2" tap.
1992 Trans Am
05-10-2023 07:19 PM
gixxer92
09-01-2015 04:32 PM
Hawkeye1980
08-31-2015 07:09 AM
theshackle
08-22-2015 06:52 PM
blackd-out z28
08-15-2015 08:18 PM
Quick Reply: harmonic balancer center bolt stripped
