86 Iroc FOR SALE - Mint, 383 solid roller 575hp 11.6 @123 on Street Radials
1986 Iroc Z28 camaro metallic blue w/gray cloth interior,full power,auto,alloy rims. Full gauges
Tach w/shift light, water temp, oil press.
There is ABSOLUTELY NO RUST anywhere on this car. Interior is perfect, exterior has a few scratches here and there.
The motor currently in the car is a 10.8:1 compression 383 Solid Roller small block w/1800 miles that produces 575 flywheel horsepower.
Forged 400 crank and rods, TRW racing pistons with dropped ring lands. All ARP bolts, rods,mains, and head bolts. Moroso oil pump and pick-up, moroso oil pan. Pete jackson gear drive, Aluminum front cover, edelbrock water pump. Brodix Track 1 Heads 2.08 intake and 1.60 exhaust, Lunati pro 1.5 roller rockers w/Lunati stud girdle. Solid roller Comp cams .630in .630ex. 106ls 244dur. @ .050 camshaft. Compcams Solid roller lifters. Compcams custom length pushrods. Edelbrock Air Gap high rise single plane intake. Holley 4150 Pro Series 830CFM mechanical Secondaries Carb. Lots of braided line, Aeromotive fuel pressure regulator w/return line and gauge.
Hooker Supercomp 1&3/4in. long tubes, Quarter Master High Torque mini starter.
Trans was built by DRC Performance Trans in Elk Grove. It's a 350 turbo trans with Precision 3600 stall converter,B&M trans cooler. Trans does slip but I can put a new trans in or compensate for price. BCustom Drive shaft and custom exhaust.
10 bolt rear end with 342 gears and auburn pro series diff.
Full race weight 3140lbs. (without driver)
I NEED TO SELL!!!!!!
Asking $10,575
Call me at 847-401-9684 leave message and I'll get right back to you or post here.
[This message has been edited by FlynIroc (edited September 28, 2001).]
Asking $10,575
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I am thinking this post will be closed.
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
yep being closed for lack of tech content
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
colton_carlson
03-08-2019 12:21 PM
mustangman65_79
08-11-2015 03:17 PM
