Quick question.. spherical canister?
Old 08-02-2005, 03:06 PM
SinCity's Avatar
Car: 1988 Chevrolet Camaro SPL
Engine: 350 Modified
Transmission: T-5 manual
Axle/Gears: Ford 9in - 3.50
My friend has a 3rd Gen V8 Camaro 82 with a spherical case or canister on the driver's side in front of the tire.. I've never seen one before; does anyone know what it is?
Old 08-02-2005, 03:38 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It's a vacuum reservoir to keep accessories such as cruise control and heater routing operating during low vacuum conditions, such as going up hills.
Old 08-02-2005, 04:04 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
also known as the "BLACK ORB OF POWER"
this is all the info i can share with you without an in depth interview to make sure your not with the Russians
Old 08-03-2005, 10:02 AM
Brian Murray's Avatar
Car: '91 Pontiac Firebird
Engine: 4-bolt 350 TBI w/ Holley ProJection
Axle/Gears: 3.08, 10bolt
Ah crap, you mean I wasnt supposed to tell the russkis?
Old 08-03-2005, 10:13 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Oh, no!!!!
You told them about the Orb of Power?!?!?!?!?!?
Now what are we goinbg to do????
Old 08-03-2005, 10:58 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
By his wording, it sounds as if he is describing the charcoal canister. For the original poster, if it looks like a coffee can, it is the charcoal canister, designed to catch fuel vapors and allow them to be recycled through the intake for combustion. If it looks like a big black softball on steroids, then it is a vacuum container as five7 described.
On a side note, isn't the phrase "spherical canister" kind of contradictory?
Old 08-03-2005, 11:00 AM
vernw's Avatar
YEP! Spherical meant a "ball shaped object" to me.
I'll shut up now and crawl back into my hole.....
Old 08-03-2005, 11:02 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Mines in a bag in the back, no wonder its so slow.
Old 08-03-2005, 11:15 AM
ROFL
Old 08-03-2005, 12:38 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
In front of tire is vacuun resevoir if round with only one line, vapor canister has electrical connection, and a couple of lines.
Old 08-03-2005, 02:47 PM
Axle/Gears: 3:08
shhhhhhhhhhhhhhhh the russians
F-body-fan
01-12-2023 01:49 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
meeklay812
10-01-2015 03:46 PM
Galaxie500XL
10-01-2015 01:05 PM
3.8TransAM
09-27-2015 08:37 PM
Quick Reply: Quick question.. spherical canister?
