Shifter Too Loose - How to fix?
Old 11-14-2001, 12:00 AM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Well like the topic says...
I have an 86' z28, and the tranny was replaced before I bought it, im not sure if that has anything to do with my problem or not.
My problem is that while in a gear, lets say Drive, I can freely move the shifter back and forth in drive. (like there is a feeling of at least one - 2 inches between Neutral and 2nd gear... ) Jeesh this is hard to explain. Basically I just have lag inbetween each gear on my shifter. Understand?
Now how do I fix.. Do i need to replace the cable? (maybe its streched...) Adjust something? Whuts up?
No License, No Hope.
FILTERCHARGED BABY
http://www.crushed.org
Old 11-14-2001, 09:45 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Check the bolts on the bracket holding the cable to the transmission. They sometimes loosen up and make the shifter feel very loose.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old 11-14-2001, 11:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
My car was doing the exact same thing whe ni bough it. turns out the cable was messed up and had a piece of a clothes hanger holding the cable to the lever on the transmission. I replaced the cable and its fine now. The previous owner of my car is freaking retarded...
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old 11-15-2001, 02:21 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
on my 86 the nut that holds the lever on the shaft going into the trans was loose... lined t up in nuetral tightened the nut and all was good...
zroc
Old 11-15-2001, 02:31 AM
LastHopeRS's Avatar
yup...check the bolts on the cable bracket...last year my shifter was so loose she would slip into different gears at stoplights!!!!!! but a couple quick turns on the bolts, fixed.
Old 11-16-2001, 10:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, on the stock shifter, there's nothing to 'hold' the stick in gear. If you remove the cable completely from teh trans, you'll see how easily that shifter moves around! The only "lock" that stock shifter has is from going "down" a gear, say, from D to 2. But it relies on the 700r4's manual shift lever to hold itself "up".
-Tom P (Hot rodded 1986 Firebird 2.8l)
92firebirdguy
09-01-2016 07:53 AM
AmpleUnicorn88
Interior Parts Wanted
16
11-29-2015 05:45 PM
3rdgenkindagal
09-13-2015 02:02 PM
TheTraut88
09-11-2015 05:16 AM
Fronzizzle
09-08-2015 12:10 PM
Quick Reply: Shifter Too Loose - How to fix?
