first engine start problems!please help!!
Old 09-05-2007, 12:50 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello
i`m from europe (the netherlands)
and my english is not so great but i try to do my best!
i have a camaro iroc-z from 88 with a 305 tpi 5 speed manual
when i start the car (cold or hot) for the first time it shut down!
i must first run in or street than it is okey!
or i must step a few minuts on the gas when i stand still!
i have check the system on vacum leaks but no leaks found
i have check the MAF sensor but they`s okey
i have cleaned up the throttle body but still start problems!
i have hear somewhere that there are any sensors on the engine
( AIG = air iddle ...... or cold start sensor)
is here anybody who can help me to fix this problem??
and do sombody know cheap parts to buy ( sensors)
gr Dennis (from the netherlands)
Old 09-06-2007, 07:29 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: first engine start problems!please help!!
I would check the fuel filter, TPS sensor voltage, and the fuel pressure at the fuel rails.
Hope this helps.
Old 09-06-2007, 02:04 PM
Car: camaro iroc-z
hey hello thanks for the answer,but why checking the fuel filter??when i drive a few minuts the engine is okey!only start problems with the first start cold or hot!and what is a TPS sensor????howmuch fuel pressure must the fuel rails have???gr dennis
Frozer!!!
01-19-2024 04:55 PM
92camaroJoe
07-29-2023 07:57 PM
zeitghaist
08-18-2015 07:33 AM
92camaroJoe
08-13-2015 06:07 AM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: first engine start problems!please help!!
