why is it...
Old 04-20-2011, 11:30 AM
dustinxix's Avatar
Car: 1988 firebird formula
Engine: 5.7 TPI :)
Transmission: Auto :(
Axle/Gears: 9 bolt LSD
why is it...
just out of curiousity, why is it that right before an engine is about to blow, it has way more power than usual? and its not just with cars, its with almost everything else, its happened on my dirtbike and four wheeler too and i am real curious as to why? sorry if this is in the wrong section, didnt know where else to put it :P
Old 04-20-2011, 11:44 AM
Received 1,672 Likes on 1,269 Posts
Re: why is it...
I think, if you just turn your question around backwards, you'll find that it answers itself.
The engine blows because it was producing more power than it had in the past, and it reached its threshold of whatever. Not, the engine is producing more power because it's about to blow.
I'm reminded of someone who was trying to prove to me that everybody was to some degree psychic, using as evidence, the question "ever notice that when you're looking for something, the place you find it is the last place you look?" Well duhh.... when you find it, you STOP LOOKING, so of course it's the last place you look. You don't have to invoke "psychic" to explain that. Or, the aviation truism, that when you run out of fuel, you ALWAYS have JUST ENOUGH left to transport you fully to the scene of the crash. Gotta keep your reasoning in a straight line.
See my signature for a simple mental discipline that helps eschew obfuscation.
Old 04-20-2011, 01:18 PM
dustinxix's Avatar
Engine: 5.7 TPI :)
Re: why is it...
wow thats a good way of looking at it lol thanks!
Old 04-20-2011, 05:45 PM
dusting901's Avatar
Car: 1974 caprice
Engine: tpi 400
Transmission: turbo 350
Axle/Gears: i was robbed of this knowledge
Re: why is it...
hey my names dustin too
Old 04-20-2011, 06:04 PM
Twin_Turbo's Avatar
Re: why is it...
I think it's a myth, if an engine is about to blow you usually feel it having severely reduced power, as if the pedal is dead and then it goes.
Old 04-20-2011, 06:26 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: why is it...
Probably matters most why the engine blew. I've had some demo derby cars that had more power before the engine blew, but that's because we had them running beyond their designed specs, causing them to overheat.
On the other hand, I had a Blazer that started loosing compression on a cylinder right before the motor blew, and I could barely get it to move. It probably had 25% power in that final drive.
Old 04-20-2011, 07:34 PM
Benjam88's Avatar
Re: why is it...
A racer from back in the day called Smokey Yunick discovered this phenomenon as well. As the motor starts to over heat it starts to atomize and burn fuel much more efficient. Smokey built a car that would heat the fuel to over 400 degrees before it was sent into the combustion chamber. Really interesting stuff. He made an old Fiero that would get 50 mpg and do 0-60 in 6 seconds or less.
http://www.legendarycollectorcars.co...clusive-video/
Old 04-20-2011, 07:59 PM
campin1983's Avatar
Re: why is it...
That actually makes a ton of sense if you think about it. So assuming the dying motor is overheating and has not yet had a catastrophic failure, it may seem more powerful for just a bit. And since that is a fairly common scenario, it makes perfect sense why it would appear the motor is running better before it died.
I recall watching a NASCAR race that Jeff Gordon was leading, and his crew claimed the car was running poorly, so they blocked the grill enough to cause the engine to be hot enough it was within a few degrees of blowing and he was leading the field. Eventually the engine gave out...
Old 04-20-2011, 09:43 PM
dustinxix's Avatar
Engine: 5.7 TPI :)
Re: why is it...
that would definately explain why then. thanks for all the useful info guys!
Old 04-21-2011, 11:54 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: why is it...
I understand your point, but people usually say "it was in the last place I would have looked", not "it was in the last place I looked".
okfoz
10-13-2015 02:19 PM
85cmroz28
10-04-2015 09:44 PM
luvofjah
09-26-2015 08:28 PM
CORV3TT3
08-23-2015 11:26 AM
CD MaroMan 91
11-28-2001 04:45 AM
Quick Reply: why is it...
