Gasket leftovers
Old 04-20-2011, 11:05 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Gasket leftovers
Is this clean enough for new intake gaskets? I think the intake is pretty decent now but still some minor crap on heads.
I spent at least 5 hours on these things. 90% came off fine but last 10% stuck on way too much! Turned out a hammer worked best to break up the thicker spots to be able to scrape them clean. BUt there is still some residue. The intake I bit the bullet and used light pressure with 400grit on an orbital.
The tought spots are around the coolant passages. Even Aircraft paint remover does not work.
Are they clean enough now?
Old 04-20-2011, 11:13 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Gasket leftovers
Hammer? Orbital sander?
What about a razor blade or lightly wire wheel?
Old 04-22-2011, 05:44 PM
Dennis-Z28's Avatar
trust me, a plastic putty knife is the first thing I tried, then a metal one. Then a razor, then chemicals. This stuff is stuck on!
db057
01-10-2020 08:55 PM
sheachopper
07-31-2019 11:27 AM
TP355Z
Exterior Parts Wanted
10-21-2015 01:05 AM
Jonas Earl
09-27-2015 07:39 AM
hdis2002
09-08-2015 02:52 PM
Quick Reply: Gasket leftovers
