what type of compression should I have, can I run pump gas??
Alright i have a 88 irocz 305tpi iam in the process of building a 400sbc 30 over.. so far i have bought the weiand stealth ram kit, afr 195 heads 65cc, xfi 280 retro fir hydraulic roller cam 280 288 duration @50: 230 236 valve lift 576..eagle rotating assembly all forged mahle pistons, h beam rods 6 inch and a forged crank...
Car: 1988 Camaro
Re: what type of compression should I have, can I run pump gas??
Need more info. What cc pistons?
I see the eagle kits listed with everything from 16cc dish, to 5cc flat top to 4cc domes
Also whats your block deck height? Are you/did you have block decked?
What head gasket thickness and bore size?
Using .025" deck height, 4.166 x .038" head gaskets I come up with
16cc dish 9.76:1
5cc flat top 10.91:1
4cc dome 12.10:1
The 9.76 will run on pump fuel just fine
The 10.91 will run on pump fuel but not with your small cam. You would need to go up about 15* duration.
The 12.10 will not run on pump fuel, would need atleast 100-105 octane
16cc dish 9.76:1
4cc dome 12.10:1
16cc dish 9.76:1
4cc dome 12.10:1
16cc dish 9.76:1
4cc dome 12.10:1
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
