Help, won't start/ turn over...
Old Oct 21, 2014 | 08:59 PM
rcswamper's Avatar
Yes I know this has addressed here on this subject, but I have been unable to fix the problem. Here is the problem, you turn the ignition key and you hear everything power on, and turn to start and their is nothing, no click, the lights do not dim, nothing.
Here is what we have done so far, I can jump starter with a large screw driver and with ignition on the car will start. I replaced the solenoid on the starter and the neutral safety switch and still nothing. This is where I am out of idea's, any suggestions on what I should check next?
I have 1985 Camaro with a 5.7L IROC motor. Thanks for any help.
Old Oct 21, 2014 | 09:08 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: Help, won't start/ turn over...
start tracing the voltage back from the solenoid started wire with a multimeter.
Old Oct 21, 2014 | 09:23 PM
88Camiroc's Avatar
Car: 88 iroc
Engine: 350 4-bolt main 010 bored .040 over
Transmission: t-5 manual
check your fuses. I worked on a car not to long ago and we had the same symptoms and it turned out being one simple fuse. So check the fuses and your relays
Old Oct 24, 2014 | 09:24 AM
rcswamper's Avatar
Thank you for all the advice. I did finally find the the ignition switch on top of the steering column had come loose and moved keeping the switch from engaging. Readjusted it and it works like a charm now. Hope this helps anyone having the same issues.
Prodigious
Nov 7, 2020 09:23 AM
Derick15
Sep 17, 2016 05:28 PM
WIzmo
Aug 30, 2015 02:30 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
